[MAPSERVER-USERS] CLOSE_CONNECTION=DEFER - Segmentation fault
Ivan Mincik
ivan.mincik at gmail.com
Mon Mar 3 16:46:18 EST 2008
thanks a lot, I am just compiling Mapserver 5.0.3 and ready to try upgrade.
Ivan
On Monday 03 March 2008 21:53, rich.fromm wrote:
> hrach wrote:
> > I use mapserver 4.10.3, postgresql 8.1, Debian Etch.
> > Is anybody using CLOSE_CONNECTION=DEFER without any problems ?
> I am now using it fine with mapserver 5.0.0 after applying the patch for
> bug 2497:
> http://trac.osgeo.org/mapserver/ticket/2497
> I don't know if 4.10.3 is different enough for that patch to be applicable
> or not. But if it's not too hard to upgrade, you might want to try a later
> version (e.g. 5.0.2) plus that patch. Note that the patch may make it into
> the 5.0.3 release (it was originally targetted for 5.2).
> You also might want to take a look at the following related mailing list
> threads:
> http://www.nabble.com/Segmentation-fault---mapserver---postgis-to12653945.h
>tml#a12674499
> http://www.nabble.com/postgres-transaction-warnings-to15749333.html
> - Rich
