[MAPSERVER-USERS] msProcessProjection(): Projection library error.
rich.fromm
nospam420 at yahoo.com
Tue Mar 4 19:15:36 EST 2008
rich.fromm wrote:
> I am in the process of running a test with the code from the trunk
> including
> this change, plus a patch for bug 2497. It can take several hours for
> problems to be reported, so my debugging cycle is a little slow here.
The test completed, there were no errors reported by mapserver. For more
details, see:
http://trac.osgeo.org/mapserver/ticket/2533#comment:4
rich.fromm wrote:
> Even if this solves the projection errors reported in
> msProcessProjection(), I
> suspect there still might be a separate error causing a crash.
While it's only a single (long) test, there were also no crashes.
I am in the process of running another test, this using a build of the tip
of branch-5-0, along with local patches both for bug 2497 and for bug 2533
(in other words, this patch).
View this message in context: http://www.nabble.com/msProcessProjection%28%29%3A-Projection-library-error.-tp15815968p15840243.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
