[MAPSERVER-USERS] CLOSE_CONNECTION=DEFER - Segmentation fault
Dave Fuhry
dfuhry at gmail.com
Wed Mar 5 16:41:44 EST 2008
Ivan,
Thanks for the problem report. If you are using fastcgi, you may
need to restart it.
The only two places PQconnectdb is called is in msPOSTGISLayerOpen
and in msPOSTGRESQLJoinConnect, which operates independently, not
using cursors or the connection pool. With a patched
msPOSTGISLayerOpen, PQexec(layerinfo->conn, "BEGIN") is always called
right after connecting, before any queries and before the connection
ends up in the connection pool.
So I'm wondering if you've put the new mapserv executable in your
cgi-bin, but not restarted the webserver, and it's pulling old
connections out of the fastcgi connection pool, which have not had
PQexec(layerinfo->conn, "BEGIN") issued to them (and thus, no
transaction started).
Try restarting fastcgi. Depending on your configuration,
restarting your webserver may automatically restart fastcgi, or you
may have to specifically restart the fastcgi service/daemon on that
machine.
Please let us know if this fixes the problem.
Thanks,
Dave
On Wed, Mar 5, 2008 at 7:26 AM, Ivan Mincik <ivan.mincik at gmail.com> wrote:
> Nothing is perfect. There are no problems with applied patch when browsing the
> map. But when I use identify object query from php5-mapscript the problem is
> rising again.
> I have in postgresql log:
> 2008-03-05 13:19:30 CET WARNING: there is no transaction in progress
> 2008-03-05 13:19:30 CET ERROR: cursor "mycursor" does not exist
> 2008-03-05 13:19:31 CET ERROR: DECLARE CURSOR may only be used in transaction
> blocks
> 2008-03-05 13:19:31 CET WARNING: there is no transaction in progress
> 2008-03-05 13:19:31 CET ERROR: cursor "mycursor" does not exist
> 2008-03-05 13:19:32 CET ERROR: DECLARE CURSOR may only be used in transaction
> blocks
> 2008-03-05 13:19:32 CET WARNING: there is no transaction in progress
> 2008-03-05 13:19:32 CET ERROR: cursor "mycursor" does not exist
> 2008-03-05 13:19:34 CET ERROR: DECLARE CURSOR may only be used in transaction
> blocks
> 2008-03-05 13:19:34 CET WARNING: there is no transaction in progress
> 2008-03-05 13:19:34 CET ERROR: cursor "mycursor" does not exist
> 2008-03-05 13:20:10 CET LOG: could not receive data from client: Connection
> reset by peer
> 2008-03-05 13:20:10 CET LOG: unexpected EOF on client connection
> reset by peer
> 2008-03-05 13:20:10 CET LOG: autovacuum: processing database "gisplan"
> reset by peer
> reset by peer
> reset by peer
> reset by peer
> reset by peer
> reset by peer
> reset by peer
> 2008-03-05 13:20:40 CET WARNING: there is already a transaction in progress
> 2008-03-05 13:20:41 CET WARNING: there is already a transaction in progress
> 2008-03-05 13:20:42 CET WARNING: there is already a transaction in progress
> 2008-03-05 13:20:43 CET WARNING: there is already a transaction in progress
> 2008-03-05 13:20:44 CET WARNING: there is already a transaction in progress
> 2008-03-05 13:20:45 CET WARNING: there is already a transaction in progress
> 2008-03-05 13:20:46 CET WARNING: there is already a transaction in progress
> 2008-03-05 13:20:47 CET WARNING: there is already a transaction in progress
> 2008-03-05 13:20:48 CET WARNING: there is already a transaction in progress
> 2008-03-05 13:20:49 CET WARNING: there is already a transaction in progress
> 2008-03-05 13:20:50 CET WARNING: there is already a transaction in progress
> ivan
> On Monday 03 March 2008 21:53, rich.fromm wrote:
> > hrach wrote:
> > > I use mapserver 4.10.3, postgresql 8.1, Debian Etch.
> > > Is anybody using CLOSE_CONNECTION=DEFER without any problems ?
> > I am now using it fine with mapserver 5.0.0 after applying the patch for
> > bug 2497:
> > http://trac.osgeo.org/mapserver/ticket/2497
> > I don't know if 4.10.3 is different enough for that patch to be applicable
> > or not. But if it's not too hard to upgrade, you might want to try a later
> > version (e.g. 5.0.2) plus that patch. Note that the patch may make it into
> > the 5.0.3 release (it was originally targetted for 5.2).
> > You also might want to take a look at the following related mailing list
> > threads:
> > http://www.nabble.com/Segmentation-fault---mapserver---postgis-to12653945.h
> >tml#a12674499
> > http://www.nabble.com/postgres-transaction-warnings-to15749333.html
> > - Rich
> mapserver-users at lists.osgeo.org
