[mapserver-users] combine many georeferenced tifs in one layer
Janosch.Skrobek at trier.de
Mon Mar 10 08:50:59 EDT 2008
Thanks a lot Bart and you too Till!
I had some troubles with the wildcards (*.tif) since the gdaltindex binary from gdal.org doesn't seem to support them - although it says so in the manual. I googled a bit and found fwtools which have gdaltindex implemented as well and here the wildcards work.
But just as I thought I get follow-up problems :)
1) gdaltindex puts out a warning when processing my tiffs:
Warning 1:TIFFFetNormalTag:ASCII value for tag "copyright" contains null byte in value; value incorrectly truncated during reading due to implementation limitations
But luckily that doesn't seem to influence the result. Still I would like to know what it is trying to tell me and google doesn't know :)
2) when loading the layer it takes at least 20seconds for mapserver to show it. I understand it is because of big amount of data? (50files, all in all 40MB) Is there any way to speed this up?
Thank you very much for your help!
Janosch
-----Ursprüngliche Nachricht-----
Von: Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
Gesendet: Montag, 10. März 2008 11:49
An: Skrobek, Janosch; mapserver-users at lists.osgeo.org
Betreff: Re: [mapserver-users] combine many georeferenced tifs in one layer
You need to create a tileindex using gdaltindex, and then reference that
tileindex in your layer.
See the RASTER HOWTO for details, chapter 4:
http://mapserver.gis.umn.edu/docs/howto/raster_data
Best regards,
Bart
OSGIS, Open Source GIS
http://www.osgis.nl
--------- Oorspronkelijk bericht --------
Van: Janosch.Skrobek at trier.de
Naar: mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
Onderwerp: [mapserver-users] combine many georeferenced tifs in one layer
Datum: 10/03/08 08:45
> Hello everyone!
> I'm just getting started with Mapserver and have worked my way through
> the tutorial made by Pericles S. Nacionales. Now I have started to work
> on my own mapserver application but am experiencing some problems.
> I have a shapefile of my hometown which I use as the background layer.
> Now I want to add Raster Data, I have 50 georeferenced tif tiles of the
> area. I could add them in an own layer each but I would rather like all
> these tiffs to be in one layer. Is there a way to tell mapserver to use
> all tiffs in a folder for a layer? If not, what would be the best way to
> combine these tiffs into one big image?
> I hope you can help me out :)
> Best Regards
> Janosch
> Diese E-Mail kann vertrauliche und/oder rechtlich geschützte Informationen
enthalten.
> Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich
erhalten haben,
> informieren Sie bitte sofort den Absender und vernichten Sie diese E-Mail.
Das unerlaubte
> Kopieren sowie die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
Der
> rechtsverbindliche elektronische Schriftverkehr mit der Stadt Trier ist
über diese
> E-Mail-Adresse derzeit noch nicht möglich.
Diese E-Mail kann vertrauliche und/oder rechtlich geschützte Informationen enthalten.
Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich erhalten haben,
informieren Sie bitte sofort den Absender und vernichten Sie diese E-Mail. Das unerlaubte
Kopieren sowie die unbefugte Weitergabe dieser E-Mail ist nicht gestattet. Der
rechtsverbindliche elektronische Schriftverkehr mit der Stadt Trier ist über diese
