[mapserver-users] combine many georeferenced tifs in one layer
Mike Meier
stirc at gmx.de
Mon Mar 10 13:50:20 EDT 2008
Hi Bart,
why without .shp suffix? I don't find this hint at the Mapfile reference
or in a Trac Ticket.
Greetings
Mike
Bart van den Eijnden (OSGIS) schrieb:
> You can do the following things to speed up performance:
> * create a spatial index on your tileindex shapefile with shptree (also make
> sure you reference your TILEINDEX in the MAP file without the .shp suffix)
> * create overviews in the tiff files using gdaladdo
> Best regards,
> Bart
> OSGIS, Open Source GIS
> http://www.osgis.nl
> --------- Oorspronkelijk bericht --------
> Van: Janosch.Skrobek at trier.de
> Naar: mapserver-users at lists.osgeo.org <mapserver-users at lists.osgeo.org>
> Onderwerp: RE: [mapserver-users] combine many georeferenced tifs in one
> layer
> Datum: 10/03/08 10:51
>> Thanks a lot Bart and you too Till!
>> I had some troubles with the wildcards (*.tif) since the gdaltindex binary
> from gdal.org doesn't seem to support them - although it says so in the
> manual. I googled a bit and found fwtools which have gdaltindex implemented
> as well and here the wildcards work.
>> But just as I thought I get follow-up problems :)
>> 1) gdaltindex puts out a warning when processing my tiffs:
>> Warning 1:TIFFFetNormalTag:ASCII value for tag "copyright"
> contains null byte in value; value incorrectly truncated during reading due
> to implementation limitations
>> But luckily that doesn't seem to influence the result. Still I would like
> to know what it is trying to tell me and google doesn't know :)
>> 2) when loading the layer it takes at least 20seconds for mapserver to
> show it. I understand it is because of big amount of data? (50files, all in
> all 40MB) Is there any way to speed this up?
>> Thank you very much for your help!
>> Janosch
>> -----Ursprüngliche Nachricht-----
>> Von: Bart van den Eijnden (OSGIS) [mailto:bartvde at osgis.nl]
>> Gesendet: Montag, 10. März 2008 11:49
>> An: Skrobek, Janosch; mapserver-users at lists.osgeo.org
>> Betreff: Re: [mapserver-users] combine many georeferenced tifs in one
> layer
>> You need to create a tileindex using gdaltindex, and then reference that
>> tileindex in your layer.
>> See the RASTER HOWTO for details, chapter 4:
>> http://mapserver.gis.umn.edu/docs/howto/raster_data
>> Best regards,
>> Bart
>> http://www.osgis.nl
>> Onderwerp: [mapserver-users] combine many georeferenced tifs in one layer
>> Datum: 10/03/08 08:45
>> > Hello everyone!
>> > I'm just getting started with Mapserver and have worked my way
> through
>> > the tutorial made by Pericles S. Nacionales. Now I have started to
> work
>> > on my own mapserver application but am experiencing some problems.
>> > I have a shapefile of my hometown which I use as the background
> layer.
>> > Now I want to add Raster Data, I have 50 georeferenced tif tiles of
> the
>> > area. I could add them in an own layer each but I would rather like
> all
>> > these tiffs to be in one layer. Is there a way to tell mapserver to
> use
>> > all tiffs in a folder for a layer? If not, what would be the best way
> to
>> > combine these tiffs into one big image?
>> > I hope you can help me out :)
>> > Best Regards
>> > Janosch
>> > Diese E-Mail kann vertrauliche und/oder rechtlich geschützte
> Informationen
>> enthalten.
>> > Wenn Sie nicht der richtige Adressat sind oder diese E-Mail
> irrtümlich
>> erhalten haben,
>> > informieren Sie bitte sofort den Absender und vernichten Sie diese
> E-Mail.
>> Das unerlaubte
>> > Kopieren sowie die unbefugte Weitergabe dieser E-Mail ist nicht
> gestattet.
>> Der
>> > rechtsverbindliche elektronische Schriftverkehr mit der Stadt Trier
> ist
>> über diese
>> > E-Mail-Adresse derzeit noch nicht möglich.
>> > _______________________________________________
>> > mapserver-users mailing list
>> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> Diese E-Mail kann vertrauliche und/oder rechtlich geschützte Informationen
> enthalten.
>> Wenn Sie nicht der richtige Adressat sind oder diese E-Mail irrtümlich
> erhalten haben,
>> informieren Sie bitte sofort den Absender und vernichten Sie diese E-Mail.
> Das unerlaubte
>> Kopieren sowie die unbefugte Weitergabe dieser E-Mail ist nicht gestattet.
> Der
>> rechtsverbindliche elektronische Schriftverkehr mit der Stadt Trier ist
> über diese
