[mapserver-users] WFS - DescribeFeatureType
Jacolin Yves
yjacolin at free.fr
Wed Mar 12 05:30:22 EDT 2008
Mapserver is a SLD server by default (i mean no extra configuration, no extra
build), just ask to mapserv cgi and you get it. The style is the one you
setup in your LAYER CLASS object. You can even change it and send it back to
mapserver to change the style of the LAYER.
This is what I do for a simple map export to define the new opacity of the
layer, opacity changed by my openLayer side.
Y.
Le Wednesday 12 March 2008 10:22:03 Guillaume Sueur, vous avez écrit :
> Will that work if no SLD is yet associated to the mapfile and maplayer ?
> Jacolin Yves a écrit :
> > Hi,
> > With a geStyle resquest, you get something like this for the polygon
> > layer : <PolygonSymbolizer>
> > <Fill>
> > <CssParameter name="fill">#aaaa7f</CssParameter>
> > </Fill>
> > <Stroke>
> > <CssParameter name="stroke">#000000</CssParameter>
> > </Stroke>
> > </PolygonSymbolizer>
> > For a polyline layer:
> > <LineSymbolizer>
> > <Stroke>
> > <CssParameter name="stroke-width">1</CssParameter>
> > </Stroke>
> > </LineSymbolizer>
> > For a point layer:
> > <PointSymbolizer>
> > <Graphic>
> > <Mark>
> > <WellKnownName>circle</WellKnownName>
> > <Fill>
> > <CssParameter name="fill">#0000c8</CssParameter>
> > </Fill>
> > </Mark>
> > <Size>5</Size>
> > </Graphic>
> > </PointSymbolizer>
> > Y.
> > Le Wednesday 12 March 2008 10:14:07 Guillaume Sueur, vous avez écrit :
> >> which kind of SLD request ?
> >> Actually, I need the geomType to specify which SLD template to associate
> >> with the layer...
> >>> Le Wednesday 12 March 2008 10:05:11 Guillaume Sueur, vous avez écrit :
> >>>> Hi again,
> >>>> I'm trying to use describeFeatureType to retrieve type and fields of a
> >>>> given layer.
> >>>> While it looks right for attibute data, the GeomType is not precise :
> >>>> <element name="msGeometry" type="gml:GeometryPropertyType"
> >>>> minOccurs="0" maxOccurs="1"/>
> >>>> The only piece of information I get in there is that the Geometry is
> >>>> of GeometryType, which I don't need any WFS request for !
> >>>> Is there a specific METADATA item to add or use to be able to have the
> >>>> precise type (PolygonPropertyType for instance) ?
> >>>> Thanks,
> >>> Hi Guillaume,
> >>> You can use a SLD request on the layer.
> >>> Y.
Yves Jacolin
http://softlibre.gloobe.org
