[mapserver-users] MapServer 4.8.3: MapScript setProjection
Rob
gis at vanbooth.com
Wed Mar 12 07:51:42 EDT 2008
On 11/03/2008, Daniel Morissette <dmorissette at mapgears.com> wrote:
> This long time looking up EPSG projection codes is a known issue and
> I'll try to fix it for the 5.2 release.
> In the meantime, an alternative to significantly reduce the lookup time
> is to move the definitions that you use the most often (e.g. 27700 in
> this case) to the top of PROJ4's "epsg" file.
If you can afford to use a native PROJ4 definition then that will be
> even faster.
Excuse the stupid question, but what do you mean by native PROJ4
definition? Do you mean applying the inline parameters directly?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080312/68629693/attachment.html
