[MAPSERVER-USERS] cs2cs problems
Richard Duivenvoorde
rdmailings at duif.net
Mon Mar 17 10:44:27 EDT 2008
Hi Carla,
mapserver searches in the (epsg) file for the epsg code for projection
parameters. So I think IF your epsg file contains both a line with 23030
AND 4230 (mine does by default), everything should go ok if you just
make your initial projection something like:
PROJECTION
"init=epsg:23030"
END
And add your extra needed projection to the wms_srs line in you WEB-object:
WEB
"wms_srs" "epsg:23030 epsg:4230"
END
Why should you use cs2cs parameters (which is actualy a wrapper around
proj isn't it?) in you mapserver file? Mapserver is smart enough to
lookup the proj parameters from your epsg file, and uses proj itself to
reproject your data.
Hope this helps,
cfb wrote:
> Hi,
> I’m having problems with the projection again. I’ve got a shape in
> epsg:23030 (ED50 UTM 30N), but I want to set my service in epsg:4230
> (ETRS89). I’ve changed the extent, the "wms_boundingbox" and the
> "wms_latlonboundingbox" of my header’s mapfile to geographic coordinates
> (epsg:4230 for ED50), and in the projection object (always in the header, in
> the layer object I leave epsg:23030) I put:
> PROJECTION
> 'cs2cs +from +init=epsg:4230 +to +proj=4258 +no_defs +no_defs +no_defs
> +no_defs +ellps=GRS80 +datum=ETRS89 +no_defs +units=m'
> END http://www.nabble.com/file/p16092875/epsg epsg
> For the second reference system, I’ve also tried with “+proj=longlat” and
> with “+init=epsg:4258”, but I get always the same error:
> msProcessProjection(): Projection library error. projection not named
> The epsg file of my proj4 is attached (ms4w v. 2.2.7, MapServer 5.0.2)
> Thanks in advance!!
