[mapserver-users] shp2img bug? included map files
Jeff McKenna
jmckenna at dmsolutions.ca
Wed Mar 19 13:26:29 EDT 2008
I have no problems using shp2img and including hundreds of files (with
MapServer 5.0.2). I store all layers in ".lay" files, and then my
master mapfile might look like this (where 'layers' is a folder in the
same directory as the master mapfile):
INCLUDE "./layers/base/bathymetry.lay"
INCLUDE "./layers/base/canada_land.lay"
What is your error with shp2img?
-jeff
Steven Lehr wrote:
> This software is outstanding, and I appreciate all you guys who support
> this project. I came across this and did not see anything on the bug
> page for shp2img and included map files so I'm just forwarding this
> along. Sorry if this is a known issue or I'm using it incorrectly.
> shp2img does not look like it follows included map files.
> I have aerial photography in a separate map file.
> I tried using a local path, and a full path, though they did not render
> the aerials
> INCLUDE "/maps/aerials.map"
> INCLUDE "aerials.map"
> INCLUDE "./aerials.map"
> Though when I moved the aerial layer into my map file, it rendered
> successfully.
> MapServer version 5.0.1
