Fwd: [MAPSERVER-USERS] Fwd: CLOSE_CONNECTION=DEFER - Segmentation
fault
Ivan Mincik
ivan.mincik at gmail.com
Thu Mar 20 04:16:26 EDT 2008
I have applied new patch ms_postgis_fix_trans_state.diff to mapserver-5.0.2
sources from debian unstable and recompiled.
Then I have:
1. restarted apache
2. restarted postgresql-8.1
3. restarted browser (deleted cache)
And started this test with p.mapper 3.2 application:
1. Browsing the map (moving, zooming out, zooming in, adding some more layers)
2. Using identify ({map,layer}Obj_queryBy{Point,Rect,etc.}) - ERROR:
cursor "mycursor2 immediately
3. Browsing the map (moving, zooming out, zooming in)
4. Using identify ({map,layer}Obj_queryBy{Point,Rect,etc.}) - ERROR:
Result:
With this patch it is not possible to do neither a singel object query. (with
older patch it was possible few times).
After "ERROR: cursor "mycursor2" does not exist" it is possible to continue
browsing the map again and object query fill finish with same result as
above.
log is here:
http://projects.gpsmapy.sk/logs/ms_postgis_fix_trans_state_patch.log
Thanks a lot for help
Ivan
On Wednesday 19 March 2008 23:32, you wrote:
> On Wed, Mar 19, 2008 at 3:19 PM, No Spam <nospam420 at yahoo.com> wrote:
> > --- Dave Fuhry <dfuhry at gmail.com> wrote:
> > > I think the correct way to solve the problem would be to first, get
> > > rid of the "ROLLBACK" statements in msPOSTGISLayerGetShape. Then, in
> > > msPOSTGISLayerClose, call msConPoolRelease() on the connection only
> > > if PQtransactionStatus(layerinfo->conn) == PQTRANS_INTRANS (meaning,
> > > the connection is valid and inside a transaction block).
> > > This would also solve the problem that lots of error blocks in the
> > > code call PQreset(layerinfo->conn). That resets the connection but
> > > does not call begin a new transaction. So when that connection was
> > > pulled back out of the pool, "DECLARE CURSOR ..." statements would
> > > fail.
> > Do you have any gut feel for the stability of the current code, and when
> > it is or is not a problem? Does the problem only manifest itself if one
> > calls the functions: {map,layer}Obj_queryBy{Point,Rect,etc.} ?
> > I do need the patch from bug 2497 because it solves other problems that
> > I was experiencing. And I haven't experienced any problems as a result
> > of the patch. Nevertheless, I'm trying to decide if I've just been
> > lucky, or if I'm safe as long as I don't call those functions (I don't).
> > Thanks.
> > - Rich
> Rich,
> I don't have any insight into the problems you experienced with the
> mapserver process segfaulting. I haven't seen any obvious reason why
> the older code would have caused that.
> Also Ivan: I've attached a patch which resolves invalid transaction
> state in a more comprehensive manner. A new local function
> msPOSTGISInitConnection takes the reset / ROLLBACK / BEGIN steps
> necessary to fix an unusable connection. Calls to PQreset() in the
> current code have been replaced with calls to this function, so that a
> failing query won't put a broken or non-transactional connection back
> into the connection pool.
> It is only lightly tested, but if there are no bugs, it should fix
> all of the currently known problems.
> Thanks,
> Dave Fuhry
