[mapserver-users] Mapfile for getFeatureInfo
Milo van der Linden
mlinden at zeelandnet.nl
Fri Mar 21 04:02:15 EDT 2008
The problem is with:
DATA 'the_geom FROM manis.stations'
it has to be something like:
DATA 'the_geom from (select
station_id,param1,param2,param3,param4,the_geom from manis.stations) as
stats using unique station_id using SRID=4326'
You have to explicitly address the fields you want to be available in
your DATA statement.
Kind regards,
Milo
