[mapserver-users] Minscale in web section not working?
php/mapscript
Daniel Morissette
dmorissette at mapgears.com
Fri Mar 21 14:59:07 EDT 2008
frequens wrote:
> Is anyone successfully using the MINSCALE seting in WEB section of the
> mapfile in phpmapscript (5.02).
> I can not get it to work, while the same seting for the LAYER level
> works just fine...
Do you mean that it is simply ignored, or do you get some kind of error
message? Which method do you use to handle zooming in your application?
With PHP MapScript, the $map->setExtent() method will happily let you
set an extent that results in a scale outside of the WEB's
MINSCALEDENOM/MAXSCALEDENOM. In that case it is up to the application
code to validate the map scale and prevent the user from zooming in or
out too far.
However, if you use methods like $map->zoomScale() or
$map->zoomRectangle() then it should take the WEB's
MINSCALEDENOM/MAXSCALEDEMON into account and prevent zooming outside of
that range.
Daniel
Daniel Morissette
http://www.mapgears.com/
