Fwd: [MAPSERVER-USERS] Fwd: CLOSE_CONNECTION=DEFER - Segmentation
fault
Ivan Mincik
ivan.mincik at gmail.com
Sat Mar 22 10:33:24 EDT 2008
Hi Dave and others,
>Here is the report about testing second version of
>ms_postgis_begin_to_connect.diff (03/20/08 18:35:00) in p.mapper with
>PROCESSING "CLOSE_CONNECTION=DEFER.
>I have started browsing the map, using Obj_queryBy functions, turning on and
>off different layers. Application was working smoothly without any error or
>warning in the log.
>THE PROBLEM will occur when I stop working in pmapper for a while and try to
>continue browsing. (in the log it is between 09:41:44 and - 09:46:05 and
>09:50:03 - 09:52:30) . After these pauses I had to restart browser to get
>p.mapper working again, but in 20 percent still application is still
>freezing.
>Same problems can be reproduced every new pmapper session.
I have solved this problem with php session settings so this last problem was
probably on php/p.mapper site. Now the logs are clear. Tomorrow I will test
it with more users then one.
Ivan
>Maybe I can try some session configurations in apache or postgres. Any
>advises?
>PostgreSQL log is here:
>http://projects.gpsmapy.sk/logs/ms_postgis_begin_to_connect_version2.log
>Dave, thanks a lot for Your work
>Ivan
>On Friday 21 March 2008 18:12, you wrote:
> Ivan,
> Yes, I updated the patch on the bug report page
> http://trac.osgeo.org/mapserver/ticket/2497 around the time I sent
> those emails yesterday. Download it, make sure it differs from the
> ms_postgis_fix_trans_state.diff you're currently using, `svn revert
> mappostgis.c`, and try it with the new patch.
> Sorry that was not clear.
> Thanks,
> Dave
> On Fri, Mar 21, 2008 at 4:59 AM, Ivan Mincik <ivan.mincik at gmail.com> wrote:
> > On Thursday 20 March 2008 23:46, you wrote:
> > > Ivan,
> > > Try the new version of the patch, just posted. I had accidentally
> > > removed a necessary query in msPOSTGISLayerGetShape. My tests which
> > > now include getShape() are working (with or without PROCESSING
> > > "CLOSE_CONNECTION=DEFER").
> > Hi Dave,
> > I have allready tried patch ms_postgis_fix_trans_state.diff and I have
> > posted the report. Or is there any updated version of
> > ms_postgis_fix_trans_state.diff?
> > I am sure that I have updated php_mapscript.so.
> > For sure I include my report of testing ms_postgis_fix_trans_state.diff:
> > I have applied new patch ms_postgis_fix_trans_state.diff to
> > mapserver-5.0.2 sources from debian unstable and recompiled new debian
> > package and install.
> > Then I have:
> > 1. restarted apache
> > 2. restarted postgresql-8.1
> > 3. restarted browser (deleted cache)
> > And started this test with p.mapper 3.2 application:
> > 1. Browsing the map (moving, zooming out, zooming in, adding some more
> > layers) 2. Using identify ({map,layer}Obj_queryBy{Point,Rect,etc.}) -
> > ERROR: cursor "mycursor2 immediately
> > 3. Browsing the map (moving, zooming out, zooming in)
> > 4. Using identify ({map,layer}Obj_queryBy{Point,Rect,etc.}) - ERROR:
> > Result:
> > With this patch it is not possible to do neither a singel object query.
> > (with older patch it was possible few times).
> > After "ERROR: cursor "mycursor2" does not exist" it is possible to
> > continue browsing the map again and object query fill finish with same
> > result as above.
> > {map,layer}Obj_queryBy{Point,Rect,etc.} function is not
> > working also when #PROCESSING "CLOSE_CONNECTION=DEFER" is disabled.
> > So identify object is not working at all.
> > log is here:
> > http://projects.gpsmapy.sk/logs/ms_postgis_fix_trans_state_patch.log
