[mapserver-users] Different data in the same layer
René F. Viancos S.
rviancos at gmail.com
Tue Mar 25 16:51:35 EDT 2008
Hi, Check the GROUP parameter in the MapFile Documentation. With this you
can merge many layers in one grouped Layer.
Regards
René Viancos
2008/3/25, Paul Austin <mail-lists at revolsys.com>:
> What I would like to achieve is a WMS server where when the user selects
> a layer (e.g. Water) that they see Line and Polygon water features
> rendered where the lines are in the database table water_lines and the
> polygons are in the table water_polys. All the line features are
> rendered first with the polygon features rendered on top of those.
> Is it possible with mapserver to define a layer which gets data from
> multiple sources? Sort of like nested layers but where the user doesn't
> see the nested layers.
> An extension of this would to be also have different tables with data at
> different scales so the 1:20k data would be in water_20k_lines and the
> 1:250k would be in water_250k_lines.
> Throughout all of this the user just sees the Water layer.
> Cheers,
> Paul
> mapserver-users at lists.osgeo.org
René Felipe Viancos.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080325/70df2056/attachment.html
