[mapserver-users] Different data in the same layer
Paul Austin
mail-lists at revolsys.com
Tue Mar 25 17:01:00 EDT 2008
Wow, that's very subtle easy to miss!
Is there then a way to not have the layers below water show up in the
capabilities document?
Paul
René F. Viancos S. wrote:
> Hi, Check the GROUP parameter in the MapFile Documentation. With this
> you can merge many layers in one grouped Layer.
> Regards
> René Viancos
> 2008/3/25, Paul Austin <mail-lists at revolsys.com
> <mailto:mail-lists at revolsys.com>>:
> What I would like to achieve is a WMS server where when the user
> selects
> a layer (e.g. Water) that they see Line and Polygon water features
> rendered where the lines are in the database table water_lines and the
> polygons are in the table water_polys. All the line features are
> rendered first with the polygon features rendered on top of those.
> Is it possible with mapserver to define a layer which gets data from
> multiple sources? Sort of like nested layers but where the user
> doesn't
> see the nested layers.
> An extension of this would to be also have different tables with
> data at
> different scales so the 1:20k data would be in water_20k_lines and the
> 1:250k would be in water_250k_lines.
> Throughout all of this the user just sees the Water layer.
> Cheers,
> Paul
> mapserver-users at lists.osgeo.org
> <mailto:mapserver-users at lists.osgeo.org>
> René Felipe Viancos.
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20080325/1e0be7ab/attachment.html
