[mapserver-users] Projection Issues
Gabe
gabe at agtrix.com
Wed Mar 26 22:40:00 EDT 2008
Hi
I am having trouble with the projection on a raster image. The map is being
displayed but the raster layer is shifted by about 210m.
The mapfiles main projection is EPSG:4326
I have a .ecw file with this gdalinfo:
Driver: ECW/ERMapper Compressed Wavelets
Files: aerial_photo_2003.ecw
Size is 53334, 53334
Coordinate System is:
PROJCS["TMAMG55",
GEOGCS["AUSTRALIAN GEODETIC",
DATUM["AGD84",
SPHEROID["ANS",6378160,298.25]],
PRIMEM["Greenwich",0],
UNIT["degree",0.0174532925199433]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",147],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",10000000],
UNIT["Meter",1]]
Origin = (655179.380000000000000,7701896.290000000000000)
Pixel Size = (1.500000000000000,-1.500000000000000)
Corner Coordinates:
Upper Left ( 655179.380, 7701896.290) (148d29'26.84"E, 20d46'34.32"S)
Lower Left ( 655179.380, 7621895.290) (148d29'52.92"E, 21d29'55.68"S)
Upper Right ( 735180.380, 7701896.290) (149d15'32.31"E, 20d46'4.13"S)
Lower Right ( 735180.380, 7621895.290) (149d16'11.81"E, 21d29'24.34"S)
Center ( 695179.880, 7661895.790) (148d52'45.97"E, 21d 8'1.22"S)
Band 1 Block=53334x1 Type=Byte, ColorInterp=Red
Overviews: arbitrary
Band 2 Block=53334x1 Type=Byte, ColorInterp=Green
Band 3 Block=53334x1 Type=Byte, ColorInterp=Blue
I have a vector layer which was a tab file with the projection AMG Zone
55(AGD 84). This was loaded into postgis with ogr2ogr using these options
ogr2ogr -overwrite -f "PostgreSQL" PG:"<database details>" thefile.tab -nln
t_table -lco "GEOMETRY_NAME=the_geom" -t_srs EPSG:4326 -skipfailures. I
have done this before on different installations and it usually gives me a
table where srid =4326 however in this case it is giving me a newly created
srid = 32772 (this installation is different in that we are using postgres
8.3 and ms4w 2.2.7). I have checked and as far as I can tell this layer is
being displayed correctly.
here are the relevant layers from my mapfile
LAYER
NAME "Photography_2003"
GROUP "Photography_2003"
DATA "mackay/Images/aerial_photo_2003.ecw"
TYPE RASTER
STATUS ON
PROJECTION
"init=epsg:20355"
END
METADATA
"DESCRIPTION" "Photography 2003"
END
END
And
LAYER
NAME "Paddocks"
GROUP "Paddocks"
STATUS ON
DATA "the_geom from t_the_table using unique oid using SRID=32772"
TYPE POLYGON
CONNECTIONTYPE postgis
CONNECTION "<connection string>"
MAXSCALE 2000000
CLASS
NAME "Paddock"
STYLE
ANGLE 120
WIDTH 1
SIZE 13
COLOR 0 128 0
OUTLINECOLOR 0 128 0
SYMBOL "hatched"
END
END
END
Any help would be appreciated.
Gabriel
