[MAPSERVER-USERS] CLOSE_CONNECTION=DEFER - Segmentation fault
Carlos_Molina
dr.chamberlain at gmail.com
Fri Mar 28 12:47:23 EDT 2008
I miss one extra query right here:
DECLARE mycursor2 BINARY CURSOR FOR SELECT... // getShape(1)
FETCH ALL in mycursor2
CLOSE mycursor2
ROLLBACK
//////////////////////////////////////////////////////////queryByAttribute///////////////////////////////////////////////////////////////
ERROR: DECLARE CURSOR may only be used in transaction blocks
WARNING: there is no transaction in progress
statement: rollback
statement: begin
ERROR: cursor "mycursor" does not exist
ABORT
I tried this QueryByAttribute by itself, without the first QueryByRect I
showed no my last post and it seems to be missing a BEGIN statement for its
cursor.
Saludos!
Carlos_Molina wrote:
> Dave Fuhry wrote:
>> Ivan,
>> p.mapper seems to use the typical php
>> {map,layer}Obj_queryBy{Point,Rect,etc.} functions. These calls end up
>> calling the same msPOSTGIS* functions as everything else.
>> I can't seem to reproduce your problem with a simple testcase
>> (basically, the attached files). It might help if you can set
>> log_min_duration_statement = 0 in your postgresql.conf, reproduce the
>> problem, and send the output from your postgresql log file. It will
>> show all commands issued to the database, including the BEGIN, and the
>> DECLARE CURSOR ..., and FETCH for every layer.
>> I can setup p.mapper if that's necessary to reproduce the problem.
>> (By the way, I assume you're not using an ancient version of
>> postgis, in the 0.5 - 0.6 era. There is an alternate codepath for
>> that, which I have not tested.)
>> Thanks,
>> Dave
> Hello Dave,
> I've tried first and second version of your patch and both resolved my
> first issue of many many BEGIN statements being issued by cursors so my
> application went back to running smoothly. The sad part is that another
> issued arised from this patch and It's when using python mapscript and the
> drawQuery call.
> If i just render my .map file with draw() I get no trouble, but if I open
> my map file, get a single layer from it, query the layer, open the layer
> to retrieve results and call drawQuery() afterwards to render everything
> like I used to do before the patch, I get the following error(I resumed
> the sql statements):
> BEGIN
> DECLARE mycursor BINARY CURSOR FOR SELECT... // queryByPoint
> CLOSE mycursor
> SELECT * FROM... "same as above" WHILE false LIMIT 0 // Dont know why this
> is issued, might be openLayer or just to get the field names of the table
> WARNING: there is already a transaction in progress
> BEGIN
> DECLARE mycursor2 BINARY CURSOR FOR SELECT... // getShape(0)
> CLOSE mycursor2
> ROLLBACK
> BEGIN
> CLOSE mycursor2
> ROLLBACK
> statement: rollback
> statement: begin
> ABORT
> Regards
> Carlos Molina
View this message in context: http://www.nabble.com/CLOSE_CONNECTION%3DDEFER----Segmentation-fault-tp15786741p16353907.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
