[mapserver-users] Label Follows streets alignment issue
Bob Basques
bob.b at gritechnologies.com
Sat Mar 29 01:21:16 EDT 2008
Fourth on the left zoomed in. I'm not seeing an over rotation here (in
the clockwise direction). Some notes though, the last "t" character
looks a little shorter than the first "t". This makes it look like it's
a bit over rotated. Maybe trying the test with a same Character all the
way along the line. The three Letters in the word "label" are all
taller than the whole last word, which I think is also contributing to
the over-rotational perception.
Stephen Woodbridge wrote:
> thomas bonfort wrote:
>> Steve,
>> I haven't noticed anything special, nor do I really understand what
>> problem you mention.
>> attached is a test image I used to check. do you see anything wrong
>> in it?
>> could you make a minimal test case to reproduce, or attach an image
>> showing the problem?
> Thomas,
> Thank you. Your test image actually shows the issue I was mentioning.
> Look at the left column, 4th and 7th image down. It looks like the gap
> between the bottom of the text at the start of the label is farther
> from the dark edge of the line than it is at the end of the label.
> This would indicate the label is rotated fractionally too much in the
> clockwise direction.
> Some possibilities are:
> 1) it is rotated slightly off, rounding issue? other?
> 2) the jitter in the individual character placement is causing this
> 3) it is an optical illusion
> 4) it has something to do with the font being used
> 5) something else totally
> If I look at Google maps, I do not notice this effect and I have had a
> few separate clients notice this and ask about it, hence my inquiry.
> Thank you for taking your time to looks into this.
> Best regards,
> -Steve W
>> cheers,
>> thomas
>> Thomas Bonfort
>> Camptocamp France SAS
>> Tel : +33 (0)4 79 26 57 97
>> thomas dot bonfort at camptocamp dot com
>> http://www.camptocamp.com
>> On Fri, Mar 28, 2008 at 5:57 AM, Stephen Woodbridge
>> <woodbri at swoodbridge.com> wrote:
>>> Hi Thomas,
>>> I have noticed that labels in a google style symbology that follow a
>>> straight line segment at approximately 45 degrees upper left to lower
>>> right and slightly off being aligned with the street.
>>> It is just enough to be annoying once you notice it.
>>> Have you noticed this?
>>> Can this be fixed?
>>> Thanks in advance,
>>> -Steve W
>>> mapserver-users mailing list
>>> mapserver-users at lists.osgeo.org
>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
Skipped content of type multipart/related
