[mapserver-users] WMS don't load
Steve.Toutant at inspq.qc.ca
Wed Oct 1 09:11:37 EDT 2008
I agree this connection was not a good example. Before creating the
mapfile I used it to get a map on Internet Explorer to verify if I had a
network problem. Since it was working I put it in the mapfile
I created the following mapFile based on this example
http://mapserver.gis.umn.edu/docs/howto/wms_client/#adding-a-wms-layer
and it still work on one server but not on the other. I get the blank
page.
When I test the mapFile with shp2img I got this message
msProcessProjection(): Projection library error. No such file or directory
<br>
I got this message on the server who works well also. My EPSG file
contains 4326. Can't see why I get that error.
The second server is installed on a virtual environment on a vmware
infrastructure. I'll talk with our network admin to see if it could be an
issue.
Here is the mapFile I'm now using.
thanks for your help,
steve
MAP
IMAGETYPE PNG
EXTENT -80.43000 44.99000 -57.64000 62.78000
SIZE 400 300
IMAGECOLOR 255 255 255 #Background color
PROJECTION
"init=epsg:4326" #wgs84 lat long
END
WEB
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
END
LAYER
NAME "prov_bound"
TYPE RASTER
STATUS default
CONNECTION "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:42304"
"wms_name" "prov_bound"
"wms_server_version" "1.1.1"
"wms_format" "image/gif"
END
END
END
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081001/8365e0c8/attachment-0001.html
