[mapserver-users] ArcSDE MSSQL Label Items displaying incorrectly.
Nelson Soto
NSoto at plotplans.com
Wed Oct 1 10:28:33 EDT 2008
Has anyone else run into an issue where trying to display a labelitem from SDE that it is displayed incorrectly.
This is my map file, it is for highways...
MAP
NAME 'Highways 2'
SIZE 800 650
STATUS ON
EXTENT 34847.155991 780218.437305 329932.687407 959485.530395
UNITS METERS
FONTSET '../fonts/fontset.list'
SYMBOLSET '../symbols/symbol.sym'
TRANSPARENT TRUE
IMAGETYPE PNG
QUERYMAP
STATUS ON
END
LEGEND
LABEL
TYPE TRUETYPE
FONT ARIAL
SIZE 10
COLOR 0 0 0
END
STATUS ON
END
LAYER
NAME major_roads-sde
CONNECTIONTYPE PLUGIN
CONNECTION "GEOTS,port:5151,medway,sa,geosql1230"
PLUGIN "D:\ms4w\Apache\specialplugins\msplugin_sde_92.dll"
DATA "medway.DBO.fcMajRoads,SHAPE"
STATUS DEFAULT
TYPE LINE
MAXSCALE 250000
SYMBOLSCALE 900000
CLASSITEM "ADMIN_TYPE"
CLASS
NAME "State Highway"
EXPRESSION "3"
STYLE
COLOR 120 120 120
SYMBOL 'plainline'
SIZE 3
MINSIZE 1
MAXSIZE 4
END
STYLE
SYMBOL 'plainline'
SIZE 1
MINSIZE 1
MAXSIZE 2
COLOR 227 159 2
END
END
CLASS
NAME "U.S. Highway"
EXPRESSION "2"
STYLE
COLOR 120 120 120
SYMBOL "plainline"
SIZE 3
MINSIZE 1
MAXSIZE 4
END
STYLE
COLOR 109 223 77
SYMBOL "plainline"
SIZE 1
MINSIZE 1
MAXSIZE 2
END
END
CLASS
NAME "Interstate"
EXPRESSION "1"
STYLE
COLOR 120 120 120
SYMBOL "plainline"
SIZE 3
MINSIZE 1
MAXSIZE 4
END
STYLE
COLOR 255 255 136
SYMBOL "plainline"
SIZE 1
MINSIZE 1
MAXSIZE 2
END
END
END
LAYER
NAME major_roadsanno-SDE
STATUS DEFAULT
TYPE annotation
MAXSCALE 2000000
LABELITEM 'RT_NUMBER'
LABELCACHE ON
CLASSITEM 'ADMIN_TYPE'
CLASS
EXPRESSION '1'
COLOR 0 0 0 # dummy color
SYMBOL '../symbols/interstate.png'
LABEL
MINFEATURESIZE 25
MINDISTANCE 250
SIZE TINY
COLOR 254 254 254
END
END
CLASS
EXPRESSION '3'
SYMBOL '../symbols/USHWY.png'
LABEL
MINFEATURESIZE 25
MINDISTANCE 200
SIZE TINY
COLOR 0 0 0
END
END
CLASS
EXPRESSION '2'
COLOR 0 0 0 #dummy color
SYMBOL '../symbols/STHWY.png'
LABEL
MINFEATURESIZE 25
MINDISTANCE 150
SIZE TINY
COLOR 0 0 0
END
END
END
END
If I replace the RT_Number field for an integer field, it displays correctly. But if I use the RT_NUMBER (which the data exists as intended when checked) it looks like âê and so on.
-----Original Message-----
From: Andreas Albarello [mailto:andreas.albarello at territoriumonline.com]
Sent: Tuesday, September 30, 2008 4:25 PM
To: Nelson Soto
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] ArcSDE 9.3 Support.
On 30 Sep 2008, at 21:56, Nelson Soto wrote:
> After tracing dependencies with Dependency Walker, I can see sde.dll
> and
> libmap.dll aren't loading correctly when loading
> 'msplugin_sde_92.dll'.
> Any ideas on how to alleviate this?
Nelson,
dynamically loaded plugin dlls which in turn require other statically
compiled libraries is where Windows dll hell starts to get really
ugly. Windows tries to locate your sde libraries either in one of the
directories contained in your %PATH% (probably set by setenv.bat but I
don't use MS4W so I can't help you there) or, preferably, in the
application's folder. By that, if I'm not mistaken, they mean the
directory which the main executable image of your app is launched
from, so probably the one containing mapserv.exe (or maybe the one
where libmap.dll resides?). It's definitely not going to work if you
place them relative to the plugin inside your specialplugins folder as
that dll is dynamically loaded into the main application's process
space. What I'm saying is that Dependency Walker won't help you in
this case if you launch it directly on msplugin_sde_92.dll, because
what counts is what mapserver.exe/libmap.dll sees, not the plugin.
Still, if all fails, you could always just drop the sde libs into c:
\windows\system32 but I'm sure with some trial and error you'll find a
place where they get picked up correctly.
Best regards,
Andreas Albarello
Analysis & SW Development
Territorium Online srl/GmbH
Via Buozzi/Buozzistraße 12 - I 39100 Bolzano/Bozen
email: andreas.albarello at territoriumonline.com
web: www.territoriumonline.com
