[mapserver-users] Re:aaigrid display problem
Dejan.Gambin at pula.hr
Thu Oct 2 09:27:51 EDT 2008
I have sucessfully converted the ESRI ascii grid file to Geotiff using
gdal_translate. But using tiffinfo on newly created file gives me
something like this:
TIFFReadDirectory: Warning, Unknown field with tag 33550 (0x830e)
encountered.
TIFFReadDirectory: Warning, Unknown field with tag 33922 (0x8482)
encountered.
TIFFReadDirectory: Warning, Unknown field with tag 42113 (0xa481)
encountered.
TIFF Directory at offset 0x900008 (9437192)
Image Width: 1427 Image Length: 1427
Tile Width: 256 Tile Length: 256
Bits/Sample: 32
Sample Format: IEEE floating point
Compression Scheme: None
Photometric Interpretation: min-is-black
Samples/Pixel: 1
Planar Configuration: single image plane
Tag 33550: 5.000000,5.000000,0.000000
Tag 33922:
0.000000,0.000000,0.000000,6400997.500000,5041132.500000,0.000000
Tag 42113: -999
TIFF Directory at offset 0x900230 (9437744)
Subfile Type: reduced-resolution image (1 = 0x1)
Image Width: 714 Image Length: 714
Tile Width: 128 Tile Length: 128
Bits/Sample: 32
Samples/Pixel: 1
TIFF Directory at offset 0x9003f2 (9438194)
Image Width: 357 Image Length: 357
Bits/Sample: 32
Samples/Pixel: 1
TIFF Directory at offset 0x9004dc (9438428)
Image Width: 179 Image Length: 179
Bits/Sample: 32
Samples/Pixel: 1
The file is displayed correctly but when I try to build the overviews
using gdaladdo I get warnings:
Warning 1: TIFFReadDirectory:LDAY.tif: Wrong "StripByteCounts" field,
ignoring and calculating from imagelength
New file with overviews is created and everything looks fine with
gdalinfo, but tiffinfo gives the same output as before. Is this something
I need to care about or I can just ignore it?
regards, dejan
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081002/152bbbb0/attachment.html
