[mapserver-users] WMS in Google Earth
Alexandre Dube
adube at mapgears.com
Fri Oct 3 08:27:35 EDT 2008
OK, I'll try that.
Many thanks, Tom
Alexandre
Kralidis,Tom [Burlington] wrote:
> Right, those may or may not have MapServer WMSs with the service= required behaviour.
> That said, I can connect a WMS from my local ms4w to Google Earth without problem.
> Try this and check your web logs. See the actual request passed by GE, and this should help you diagnose the issue.
> Since you are using 5.2.0, I would not suspect it's an issue of a missing styles= parameter.
> ..Tom
> -----Original Message-----
> From: Alexandre Dube [mailto:adube at mapgears.com]
> Sent: Fri 03-Oct-08 08:09
> To: Kralidis,Tom [Burlington]
> Cc: MAPSERVER USERS
> Subject: Re: [mapserver-users] WMS in Google Earth
> Hi Tom,
> Thanks for your reply, but unfortunately that didn't solved the problem.
> In fact, the existing WMS servers in GE, don't use "service=WMS" in any
> "Link" string and they work...
> However, the wms_onlineresource IS always the first part of the "Link"
> string, not the actual local link you copy/paste when in the "WMS
> Parameters" menu... Does this means that GE don't accept local
> wms_onlineresource ? I think this could make sense...
> Any ideas ?
> Alexandre
>>> From: mapserver-users-bounces at lists.osgeo.org
>>> [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of
>>> Alexandre Dube
>>> Sent: 02 October, 2008 4:40 PM
>>> To: MAPSERVER USERS
>>> Back with my local WMS on GE problem. I think it has
>>> something to do with the wms_onlineresource in WEB METADATA.
>>> I downloaded the gmap datas, which are already in GE as the
>>> last WMS service available, to be able to test locally what
>>> is already working on the internet. At first, it worked in
>>> GE. Then, I noticed that the wms_onlineresource was set to :
>>> "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
>>> which seemed wrong to me, because my other map doesn't exist
>>> on the internet, only locally.
>>> So I changed it to :
>>> "http://127.0.0.1:port/cgi-bin/mapserv?map=/my/local/path/gmap
>>> 75_wms.map&"
>>> and then I doesn't work anymore... also tried :
>>> "http://127.0.0.1:port/cgi-bin/mapserv?"
>>> no result...
>>> I must be close the the answer. I have searched a lot over
>>> the internet but I haven't found anything yet. Any hints ?
>>> Alexandre
>>> Alexandre Dube wrote:
>>>> Hi list,
>>>> I'm trying to figure how to setup my own wms layer in GE. So far,
>>>> I'm able to see each layer in the "WMS Parameters", but if I select
>>>> any, I get a big red X, meaning it's not working...
>>>> If I copy the "Link" created by GE, paste it in a browser, add
>>>> "&SERVICE=WMS&BBOX=-180,-90,180,90", then I get a map. So, I don't
>>>> really know what I'm missing here. Any hint ? I use
>>> mapserver 5.2.0
>>>> on Linux.
>> This might be due to the SERVICE parameter missing WMS GetMap request.
>> If you, once you add the layer, right click and select "Properties",
>> adding "&service=WMS" to the Link string, you should be able to get a
>> valid map image returned.
>> That said, I thought we lifted the service param from WMS GetMap
>> requests (GetMap sans service= works for me in svn trunk).
>> ..Tom
Alexandre Dubé
Mapgears
www.mapgears.com
