[mapserver-users] Re: [gdal-dev] creating an epsg code that can be
used within the epsg file for fwtools and MapServer
John Mitchell
mitchelljj98 at gmail.com
Mon Oct 6 13:53:55 EDT 2008
Thanks Roger,
Since I sent out the email I was able to derive the EPSG code and the only
difference between mine and yours was that I had +units=m and you had
+to_meter=0.3048006096012192. I think that my EPSG code is correct since my
below email had the Linear Unit = Meter and +to_meter=0.3048006096012192
would mean the units was feet.
John
On Mon, Oct 6, 2008 at 1:01 PM, Roger André <randre at gmail.com> wrote:
> Hi John,
> No guarantees that I got this right, but you could try adding the following
> entry to your "FWTools/share/proj/epsg" file:
> # Guatemala Transverse Mercator
> <001234> +proj=tmerc +x_0=500000.000000 +y_0=0 +lon_0=-90.5 +lat_0=0
> +k=0.999800 +ellps=WGS84 +datum=WGS84 +to_meter=0.3048006096012192 +no_defs
> Then you should be able to acces it by using "EPSG:001234" in your -s_srs
> parameters.
> Roger
> On Mon, Oct 6, 2008 at 7:10 AM, John Mitchell <mitchelljj98 at gmail.com>wrote:
>> Hi,
>> How would I create an epsg code that can be used within the epsg file for
>> fwtools and MapServer?
>> Below is the information that I would like to use to create an epsg code.
>> What would be format for the new epsg code? Is the information listed below
>> enough to create an epsg code and if not what am I missing?
>> *The 2001 data was originally in a Guatemalan Transverse Mercator
>> coordinate
>> system with the parameters shown below:
>> Projection: Transverse Mercator
>> False Easting: 500000.000000
>> False Northing: 0.000000
>> Central Meridian: -90.500000
>> Scale Factor: 0.999800
>> Latitude of Origin: 0.0000000
>> Linear Unit: Meter
>> Geographic Coordinate System: GCS_WGS_1984
>> *Below is the gdalinfo listing for one of files that I would like to
>> associate to this new epsg code:
>> *Driver: GTiff/GeoTIFF
>> Size is 11214, 7860
>> Coordinate System is `'
>> Origin = (317049.000000000000000,**1659460.000000000000000)
>> Pixel Size = (0.500000000000000,-0.**500000000000000)
>> Metadata:
>> AREA_OR_POINT=Area
>> TIFFTAG_SOFTWARE=ERDAS IMAGINE
>> TIFFTAG_XRESOLUTION=1
>> TIFFTAG_YRESOLUTION=1
>> TIFFTAG_RESOLUTIONUNIT=1 (unitless)
>> Corner Coordinates:
>> Upper Left ( 317049.000, 1659460.000)
>> Lower Left ( 317049.000, 1655530.000)
>> Upper Right ( 322656.000, 1659460.000)
>> Lower Right ( 322656.000, 1655530.000)
>> Center ( 319852.500, 1657495.000)
>> Band 1 Block=11214x8 Type=Byte, ColorInterp=Red
>> Band 2 Block=11214x8 Type=Byte, ColorInterp=Green
>> Band 3 Block=11214x8 Type=Byte, ColorInterp=Blue*
>> Thanks,
>> John J. Mitchell
>> gdal-dev mailing list
>> gdal-dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/gdal-dev
John J. Mitchell
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081006/2297b266/attachment.html
