[mapserver-users] Creating legend
Steve Lime
Steve.Lime at dnr.state.mn.us
Tue Oct 7 11:22:02 EDT 2008
Visit:
http://www.openlayers.org/dev/examples/example-list.html
and search for untiled. There's a "WMS Untiled" example you can view the source of. The singleTile option goes in the "options" object as opposed the "params" object. Params get passed to the WMS service, options are handled by OL.
Steve
>>> Subha Ramakrishnan <subha at gslab.com> 10/07/08 9:58 AM >>>
Hi Steve,
It would be great if you can give me an example or tell me where it is
usually set in OL.
Thanks for your help.
Subha
Steve Lime wrote:
> There's nothing you have to do on the MapServer side. Looks like your OL config is wrong
> though. I think 'singleTile' is set in the wrong configuration object, perhaps others are in
> the wrong place too.
> Steve
>>>> Subha Ramakrishnan <subha at gslab.com> 10/07/08 1:30 AM >>>
> Hi,
> I am using mapserver 5.0.2 with openlayers.
> I've a problem while creating a legend for a map from mapserver.When i
> try to overlay the image from the mapserver on openlayers' base map, the
> images are rendered in tiles, and every tile has a legend and is limited
> by the size of the tile. So, i see lots of legends on the map and only
> half of them are visible as it is restricted by the tile size.
> This is my request to mapserver from openlayers
> var mapfile = layer_tablename+'.map';
> twms1 = new OpenLayers.Layer.WMS(
> layer_tablename,"http://localhost/cgi-bin/mapserv?",
> { map: mapfile,
> transparent: 'true', layers:layer_tablename,
> format: 'image/png',
> projection:"EPSG:4326",reproject:false,
> units: "m",
> singleTile: true
> },{numZoomLevels : MaxZoomLevel});
> map.addLayer(twms1);
> I am using the option of singleTile. Is there any setting to be done in
> the map file or mapserver for it render a single tile/single legend per
> image?
> Thank you.
> Regards,
> Subha
> mapserver-users at lists.osgeo.org
