[mapserver-users] Creating legend
Fawcett, David
David.Fawcett at state.mn.us
Tue Oct 7 15:04:25 EDT 2008
Or, just a straight mode=legend request to the CGI if you are using MapServer. You can pass in your extent, that will manage the scale-dependent layers.
David.
-----Original Message-----
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Roger André
Sent: Tuesday, October 07, 2008 12:06 PM
To: Steve Lime
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] Creating legend
Also, you might want to consider making a separate GetLegendGraphic WMS request and putting the legend in a separate DIV element in your web page.
Just an idea.
On Tue, Oct 7, 2008 at 8:22 AM, Steve Lime <Steve.Lime at dnr.state.mn.us> wrote:
Visit:
http://www.openlayers.org/dev/examples/example-list.html
and search for untiled. There's a "WMS Untiled" example you can view the source of. The singleTile option goes in the "options" object as opposed the "params" object. Params get passed to the WMS service, options are handled by OL.
Steve
>>> Subha Ramakrishnan <subha at gslab.com> 10/07/08 9:58 AM >>>
Hi Steve,
It would be great if you can give me an example or tell me where it is
usually set in OL.
Thanks for your help.
Subha
Steve Lime wrote:
> There's nothing you have to do on the MapServer side. Looks like your OL config is wrong
> though. I think 'singleTile' is set in the wrong configuration object, perhaps others are in
> the wrong place too.
> Steve
>>>> Subha Ramakrishnan <subha at gslab.com> 10/07/08 1:30 AM >>>
> Hi,
> I am using mapserver 5.0.2 with openlayers.
> I've a problem while creating a legend for a map from mapserver.When i
> try to overlay the image from the mapserver on openlayers' base map, the
> images are rendered in tiles, and every tile has a legend and is limited
> by the size of the tile. So, i see lots of legends on the map and only
> half of them are visible as it is restricted by the tile size.
> This is my request to mapserver from openlayers
> var mapfile = layer_tablename+'.map';
> twms1 = new OpenLayers.Layer.WMS(
> layer_tablename,"http://localhost/cgi-bin/mapserv?",
> { map: mapfile,
> transparent: 'true', layers:layer_tablename,
> format: 'image/png',
> projection:"EPSG:4326",reproject:false,
> units: "m",
> singleTile: true
> },{numZoomLevels : MaxZoomLevel});
> map.addLayer(twms1);
> I am using the option of singleTile. Is there any setting to be done in
> the map file or mapserver for it render a single tile/single legend per
> image?
> Thank you.
> Regards,
> Subha
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081007/bc695751/attachment.html
