[mapserver-users] WMS don't load
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Wed Oct 8 10:31:44 EDT 2008
Are you behind a proxy server? If you are you must add proxy settings to Apache. You can check the situation from your browser network settings. If it is using direct connection to internet then you must have some other issue.
-Jukka Rahkonen-
-----Alkuperäinen viesti-----
Lähettäjä: mapserver-users-bounces at lists.osgeo.org puolesta: Steve.Toutant at inspq.qc.ca
Lähetetty: ke 8.10.2008 16:20
Vastaanottaja: Daniel Morissette
Kopio: mapserver-users at lists.osgeo.org
Aihe: Re: [mapserver-users] WMS don't load
Thanks Daniel,
Here is the definition of the layer in my mapFile
LAYER
NAME pe
TYPE RASTER
OFFSITE 0 0 0
STATUS default
CONNECTIONTYPE WMS
CONNECTION "http://atlas.gc.ca/cgi-bin/atlaswms_fr?"
DEBUG 5
METADATA
"wms_srs" "EPSG:42304"
"wms_name" "pe_15m"
"wms_server_version" "1.1.1"
"wms_format" "image/gif"
END
END # layer pe
Here is the log
[Wed Oct 08 09:00:10 2008].480000 HTTP: Starting to prepare HTTP requests.
[Wed Oct 08 09:00:10 2008].480000 HTTP request: id=0,
http://atlas.gc.ca/cgi-bin/atlaswms_fr?LAYERS=pe_15m&REQUEST=GetMap&SERVICE=WMS&FORMAT=image/gif&STYLES=&HEIGHT=300&VERSION=1.1.1&SRS=EPSG:42304&WIDTH=400&BBOX=689899.721196215,-333292.3983286,2867511.32395514,2047197.11324934&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
[Wed Oct 08 09:00:10 2008].496000 HTTP: Before download loop
[Wed Oct 08 09:00:10 2008].667000 HTTP: After download loop
[Wed Oct 08 09:00:10 2008].667000 msHTTPExecuteRequests() timing summary
per layer (connect_time + time_to_first_packet + download_time =
total_time in seconds)
[Wed Oct 08 09:00:10 2008].667000 HTTP: request failed with curl error
code 6 () for
http://atlas.gc.ca/cgi-bin/atlaswms_fr?LAYERS=pe_15m&REQUEST=GetMap&SERVICE=WMS&FORMAT=image/gif&STYLES=&HEIGHT=300&VERSION=1.1.1&SRS=EPSG:42304&WIDTH=400&BBOX=689899.721196215,-333292.3983286,2867511.32395514,2047197.11324934&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage[Wed
Oct 08 09:00:10 2008].667000 msHTTPExecuteRequests(): HTTP request error.
HTTP: request failed with curl error code 6 () for
[Wed Oct 08 09:00:10 2008].667000 Layer 0: 0.000 + 0.000 + 0.000 = 0.000s
[Wed Oct 08 09:00:10 2008].667000 msDrawWMSLayerLow(): WMS server error.
WMS GetMap request failed for layer 'pe' (Status -6: ).
[Wed Oct 08 09:00:10 2008].667000 msDrawMap(): Layer 0 (pe), 0.000s
I get a blank image. But if I use the connection string that is in the log
file and send it directly from internet explorer I get the image.
I also tried with this layer definiton, and I got the same error
LAYER
NAME "prov_bound"
TYPE RASTER
STATUS ON
CONNECTION "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
CONNECTIONTYPE WMS
METADATA
"wms_name" "prov_bound"
END
END
thanks for your help,
Steve
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction des risques biologiques, environnementaux et occupationnels
Institut national de santé publique du Québec
945, avenue Wolfe
Québec, Qc G1V 5B3
Tél.: (418) 650-5115 #5281
Fax.: (418) 654-3144
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
