[mapserver-users] php_mapscript shared obj
Fabio D'Ovidio
fabiodovidio at gmail.com
Thu Oct 9 05:47:32 EDT 2008
Hi list !
I installed mapserver 4.10.0, PHP 5.2.0 and php_mapscript on Debian Etch.
>From PHP Web GIS application i tryed to use php_mapscript functionalities but It is not possible.
It is strange becaues I did as following:
apt-get install php5
****If i type php -m I have no mapscript module built in php!!!****
I compiled mapserver and I run:
install -s mapscript/php3/php_mapscript.so /usr/lib/php5/20060613/
ln -s php_mapscript.so /usr/lib/php5/20060613/php_mapscript_4.10.0.so
I wrote /etc/php5/apache2/conf.d/php_mapscript.ini as following:
extension=php_mapscript_4.10.0.so
If I run php.info with dl function to test mapscript installation I have the following:
*Warning*: Module 'MapScript' already loaded in *Unknown* on line *0*
*So, If I comment the line in php_mapscript.ini, the Warning disappear but Mapscript module is loaded !!! *
*It's strange because mapscript module shouldn't be loaded because of my configuration in .ini file!! Is it ?*
*I am confused... what's worng ?*
*Thanks*
Fabio D'Ovidio
mail: fabiodovidio at gmail.com
