[mapserver-users] Disappearing point in a map
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Fri Oct 10 18:55:00 EDT 2008
can't it comes from the offset of 10 pixels you're applying on the point
symbol ?
regards,
guillaume
Chip Taylor a écrit :
> I have a map where I pass in the information about a point via the URL. I am
> using mapserver version 5.2 on a Windows Server 2000. In some cases the
> point just does not appear. For example, the map extents of
> -78.9043321338311+35.0222546417047+-78.8914558661689+35.0367113582953 will
> not show a point at -78.897894, 35.029483 and yet a map extents of
> -78.9041121338311+35.0222546417047+-78.8912358661689+35.0367113582953 will
> show the point of -78.897674, 35.029483, less than 300 linear feet away.
> Here is the URL passing in the first example:
> https://devmap/bin/mapserv.exe?mode=map&map=map_files/US.map&mapsize=580
> 475&map_MyPoint_feature=new&map.layer[MyPoint]=feature+points+-78.897894+35.
> 029483+END+TEXT+%27Secondary%20Building%27END&layers=roads&mapext=-78.904332
> 1338311+35.0222546417047+-78.8914558661689+35.0367113582953&program=%2Fbin%2
> Fmapserv.exe
> And here is the mapfile:
> MAP
> NAME "US"
> STATUS ON
> UNITS DD
> EXTENT -127.00 43.00 -115.00 50.00
> SIZE 500 400
> IMAGECOLOR 156 188 217
> IMAGETYPE png
> SYMBOLSET "../etc/NAVsymbols.sym"
> SHAPEPATH "../Shape_Files/navteq_data/"
> FONTSET "../etc/fonts.txt"
> Include "InlineSyms.map"
> # Symbol for drawing Star
> Symbol
> NAME 'Star'
> TYPE VECTOR
> FILLED true
> POINTS
> 0 0.375
> 0.35 0.375
> 0.5 0
> 0.65 0.375
> 1 0.375
> 0.75 0.625
> 0.875 1
> 0.5 0.75
> 0.125 1
> 0.25 0.625
> END
> END
> # Web Interface Definition
> WEB
> # the following "preset_scales" metadata is a list of specific scales
> that
> # the mapfile is configured for. These values are not used, but can be
> # placed in other applications such as ka-Map
> (http://ka-map.maptools.org/)
> METADATA
> "preset_scales"
> "2500,7500,12000,17500,35000,75000,125000,200000,400000,750000,2000000,40000
> 00,7500000,15000000,30000000,60000000"
> END
> MINSCALE 1 # necessary for CGI point query
> TEMPLATE "../HTML_Files/sitemap.html"
> IMAGEPATH 'd:/wwwroot/tmp/'
> IMAGEURL "/tmp/"
> LOG "d:/MapLogs/mapserver.log"
> #ERROR "../maperror.htm"
> END
> # Projection Definition
> PROJECTION
> "init=epsg:4269"
> END
> # MyPoint
> LAYER
> NAME "MyPoint"
> TYPE Annotation
> STATUS DEFAULT
> METADATA
> "wms_title" "MyPoint" ##required
> END
> CLASS
> COLOR -1 0 0
> STYLE
> COLOR 255 0 0
> OUTLINECOLOR 255 255 0
> SYMBOL 'star'
> SIZE 20
> END
> LABEL
> FONT "Arial"
> TYPE TRUETYPE
> ANTIALIAS TRUE
> COLOR 0 0 0
> BACKGROUNDCOLOR 220 220 220
> OFFSET 10 0
> SIZE 10
> POSITION lr
> END
> END
> END
> END #mapfile
> Any help would be greatly appreciated.
> Chip Taylor
> Prepared Response, inc
> mapserver-users at lists.osgeo.org
