[mapserver-users] Dynamic SQL
mark balman
mark.balman at gmail.com
Tue Oct 14 03:42:49 EDT 2008
Hi All
Many thanks to Pietro Giannini and David Fawcett for your help but I
am still struggling with getting a dynamic sql statement to work. I
have gone back to trying a simple sql statement in the layer
definition which works fine like this:
LAYER
CONNECTIONTYPE postgis
NAME "kbapoly"
CONNECTION "user="" password="" dbname=kba host=localhost"
DATA "the_geom from (select gid, intname, the_geom from kbapoly where
intname = 'Tibesti massif') as myquery using SRID=4326 using unique
gid"
STATUS OFF
TYPE POLYGON
TEMPLATE "templates/kbas.html"
CLASS
COLOR 255 0 0
END
HEADER "templates/kbas_header.html"
FOOTER "templates/kbas_footer.html"
END
However, if I try the following
LAYER
NAME "kbapoly"
intname = %qtest%) as myquery using SRID=4326 using unique gid"
STATUS OFF
TYPE POLYGON
CLASS
COLOR 255 0 0
END
END
Together with the following in the template file:
<input type="hidden" name="Name" value="[qtest]">
<p><b>IntName: </b><br>
<textarea name="IntName" rows=2 cols=5>[qtest]</textarea>
<p>
<hr>
This returns the following error
[Mon Oct 13 16:54:53 2008].386000 msDrawMap(): Image handling error.
Failed to draw layer named 'kbapoly'.
[Mon Oct 13 16:58:49 2008].733000 prepare_database(): Query error.
Error executing POSTGIS DECLARE (the actual query) statement: 'DECLARE
mycursor BINARY CURSOR FOR SELECT
asbinary(force_collection(force_2d(the_geom)),'NDR'),gid::text from
(select gid, intname, the_geom from kbapoly where intname = %qtest%)
as myquery WHERE the_geom && setSRID('BOX3D(-179.699499165275
-120.200333889816,180.300500834725 119.599332220367)'::BOX3D, 4326 )'
Postgresql reports the error as 'ERROR: syntax error at or near "%"
LINE 1: ...d, intname, the_geom from kbapoly where intname = %qtest%) a...
Am I missing something obvious and doing something wrong?
Any further suggestions would be gratefully received
Thanks
Mark
