[MAPSERVER-USERS] mssql2008 binary test package available to
download
Tamas Szekeres
szekerest at gmail.com
Wed Oct 15 16:48:43 EDT 2008
I'm afraid I'd require further information about your environment,
mapfiles, sample scripts to reproduce this problem.
I've installed the binaries either with IIS and Apache but I haven't
run into this problem, however I didn't mix the dll-s with other
installations.
Here's a link to my installation displaying a single layer in IIS:
http://vbkto.dyndns.org:1280/cgi-bin/mapserv.exe?mode=map&map=sql2008.map
And the same files working in Apache:
http://vbkto.dyndns.org:1080/cgi-bin/mapserv.exe?mode=map&map=sql2008.map
The corresponding mapfile is looking something like:
MAP
NAME "SQL2008"
STATUS ON
EXTENT 500000 300000 540000 340000
SIZE 1000 1000
IMAGETYPE PNG
IMAGECOLOR 254 254 254
PROJECTION
"proj=somerc"
"lat_0=47.14439372222222"
"lon_0=19.04857177777778"
"x_0=650000"
"y_0=200000"
"ellps=GRS67"
"units=m"
"no_defs"
END
SCALEBAR
TRANSPARENT ON
COLOR 0 0 64
STATUS EMBED
POSITION LR
STYLE 1
UNITS kilometers
LABEL
SIZE medium
COLOR 0 0 64
END
END
LAYER
PROJECTION
"proj=somerc"
"x_0=650000"
"y_0=200000"
"ellps=GRS67"
"units=m"
"no_defs"
END
NAME "Erdo"
TYPE LINE
CONNECTIONTYPE PLUGIN
PLUGIN "msplugin_mssql2008.dll"
CONNECTION
"server=.\MSSQLSERVER2008;database=geodb;Integrated Security=true"
DATA "geom from erdo2 WITH(INDEX(geom_sidx)) USING
UNIQUE ID USING SRID=0"
STATUS DEFAULT
CLASS
STYLE
COLOR 255 0 0
END
END
END
END
As far as I remember FCGI support haven't been enabled with these binaries.
Best regards,
Tamas
2008/10/15 BrainDrain <paulborodaev at gmail.com>:
> I've tried this package
> it looks promising:
> but mapserv is unworking (maybe because I temporary mixed package with my
> bin files): problems with loading dll dependences (libmap, fastcgi etc)
> anyway mapscript_csharp draws layer from mssql2008 normally
> querybypoint works (at first sight)
> but now mapscript crashes (memory corruption) on layer.getFeature when I'm
> trying to get quered feature attributes
> please note that I had extra problems (mapserv illegal operation &
> terminating) with option 'PROCESSING "CLOSE_CONNECTION=DEFER"' with
> mssql2008 layer
> Tamas Szekeres wrote:
>> Hi All,
>> For those who have problems compiling from the SVN I've uploaded my
>> daily snapshot to this location:
>> http://vbkto.dyndns.org:1280/tests/release-1400-20081013.zip
>> This package should contain all of the related binaries compiled with
>> MSVC2005. Please don't mix these dll-s with other compilations to
>> avoid unexpected issues.
>> Best regards,
>> Tamas
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> View this message in context: http://www.nabble.com/mssql2008-binary-test-package-available-to-download-tp19956347p19988521.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
