[MAPSERVER-USERS] Query using template and WFS errorred on POSTGIS
G. Tiemens
Gerben.Tiemens at grontmij.nl
Thu Oct 16 08:04:12 EDT 2008
Hello List,
I want to try to get certain features-attribute information back from my
postgis database via Mapserver.
I tried this in 2 ways:
Enabeling WFS in the mapfile and making a query layer.
Both requests generate errors on the Postgis Database and i can't discover
what is going wrong.
This is the error I get:
DECLARE CURSOR can only be used in transaction blocks
When doing a WFS request, i get a bounding box (envelope), but no features
back
Error is in the logfile of the postgis.
When doing a Query (nquery) i get the error in html back:
Content-type: text/html writeLog(): Unable to access file. hierzo.log
msPOSTGISLayerGetShape(): Query error. Error executing POSTGIS SQL statement
(in FETCH ALL): DECLARE mycursor2 BINARY CURSOR FOR SELECT
"gid"::text,"provincie"::text,"oid"::text,asbinary(force_collection(force_2d(the_geom)),'NDR')
from prov2007 WHERE OID = 1 -ERROR: DECLARE CURSOR can only be used in
transaction blocks More Help: msPOSTGISLayerRetrievePGVersion(): Query
error. Error executing POSTGIS statement
(msPOSTGISLayerRetrievePGVersion():select substring(version() from 12 for
(position('on' in version()) - 13)) msPOSTGISLayerRetrievePGVersion(): Query
Both queries are also done with shapefile data, and that works fine. I get
features back (wfs) or the template (nquery) is filled in correctly
Below the parts of my mapfile and templates.
Mapfile:
LAYER NAME 'pr2007' TYPE POLYGON CONNECTIONTYPE postgis
CONNECTION 'host=127.0.0.1 user=***** dbname=*****' DATA 'the_geom FROM
pr2007' #DATA 'C:\Project\Downloads\OSM\Data\pr\pr2007' PROCESSING
"CLOSE_CONNECTION=DEFER" METADATA 'ows_title' 'prov2007'
"ows_abstract" "" "ows_keywordlist" "" "gml_featureid" "gid" ##
REQUIRED "gml_include_items" "all" ## Optional (serves all attributes
for layer) "ows_srs" "EPSG:28992" # "queryable" "true"
"wfs_geometry_element_name" "the_geom" "wfs_extent" "12500 380000 280000
550000" END #DUMP TRUE STATUS ON #DEFAULT #opacity 100
PROJECTION "init=epsg:28992" END HEADER "imapheader.html" FOOTER
"imapfooter.html" CLASS COLOR 0 0 0 TEMPLATE "bodytemplate.html"
END END
query template:
<area shape="poly" coords="[shpxy precision=0 proj=image]"
href="http://www.*****.nl/pr.hml?ID=[pr]>
Versions i use:
PostgreSQL + postgis 8.3
Mapserver: MS4W : 5.2.0
Or FWtools: 5.3-dev
All on localhost, so no firewall/security issues whatsoever.
What is the possible mistake i make? Any possible plugins or settings wrong
in database?
Greetings and thanks for help.
Gerben
View this message in context: http://www.nabble.com/Query-using-template-and-WFS-errorred-on-POSTGIS-tp20012197p20012197.html
Sent from the Mapserver - User mailing list archive at Nabble.com.
