[mapserver-users] WMS don't load
Daniel Morissette
dmorissette at mapgears.com
Thu Oct 16 15:50:55 EDT 2008
Steve.Toutant at inspq.qc.ca wrote:
> Here is the log
> [Wed Oct 08 09:00:10 2008].667000 HTTP: request failed with curl error
> code 6 () for
> http://atlas.gc.ca/cgi-bin/atlaswms_fr?LAYERS=pe_15m&REQUEST=GetMap&SERVICE=WMS&FORMAT=image/gif&STYLES=&HEIGHT=300&VERSION=1.1.1&SRS=EPSG:42304&WIDTH=400&BBOX=689899.721196215,-333292.3983286,2867511.32395514,2047197.11324934&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage[Wed
> Oct 08 09:00:10 2008].667000 msHTTPExecuteRequests(): HTTP request
> error. HTTP: request failed with curl error code 6 () for
According to http://curl.haxx.se/libcurl/c/libcurl-errors.html, error
code 6 is:
CURLE_COULDNT_RESOLVE_HOST (6)
Couldn't resolve host. The given remote host was not resolved.
Sounds like a DNS config problem on your server... can you double-check
your network settings?
> I get a blank image. But if I use the connection string that is in the
> log file and send it directly from internet explorer I get the image.
Did you try opening the URL using I.E. (or wget if it's Linux) directly
on the server that produces the error?
Daniel
Daniel Morissette
http://www.mapgears.com/
