[mapserver-users] Missing row of pixels in MapServer generated tiles
Roger André
randre at gmail.com
Sat Oct 18 22:25:06 EDT 2008
This is probably more of a TileCache question, than a MapServer one, but I
figure one of you may have had the same issue in the past. I'm using
MapServer to feed TileCache a fairly large GeoTiff with global extents,
which I'm then displaying in Google Maps as a tile layer. This has worked
well in the past, but now I'm encountering a weird problem. Some of my
tiles are being rendered by MapServer with a row of pixels missing on the
tiles will be 256 x 256 pixels, but row 256 will not contain data from my
global image, but instead will be set entirely to whatever background color
I have set in my Mapfile. The problem appears in multiple, but not all, Zoom
levels, and at different geographic locations, but always at the bottom row
of a tile.
The source image doesn't have the lines in then, so I have to believe that
the "dead" row is an artifact of the rendering process. My seed image is in
lat/lon WGS84, and the tiles are being requested in EPSG:900913. The
reprojection seems to be working correctly, insofar as image lineup with
Google Maps seems to indicate. If I take the seed image and create a very
reduced resolution version of it, then run it through TileCache, I don't get
any lines. So it seems like the lines *might* be a result of downsampling,
but since they're not present at the bottom of every image, I'm not
convinced that's the problem.
Oh, and I'm using the GD driver.
Any ideas?
Roger
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081018/644c841d/attachment.html
