[mapserver-users] NEED HELP
Jeff McKenna
jmckenna at gatewaygeomatics.com
Sun Oct 19 10:09:31 EDT 2008
ntiamoah bernard wrote:
> Hi guys,
> I have some problems here:
> 1. How can i change the coordinate system form the default geomoose
> UTM-15 to StatePlane_Indiana_East_FIPS_301_Feet?
I don't know GeoMoose, but for MapServer you can use PROJECTION objects,
as described in
http://mapserver.gis.umn.edu/docs/reference/mapfile/projection See the
"Important Notes" section of that page.
> 2. When layers delay for more than 15 seconds to display, some
> timeout popup saying" These layers have delayed, do you want to remove
> them". How can i disable this popup?
This seems to be specific to GeoMoose, so you should ask on its own
mailing list (subscribe at
https://lists.sourceforge.net/lists/listinfo/geomoose-users)
By the way, you might want to use the MapServer shp2img utility (with
the '-all_debug 5' switch) to see draw speeds for your layers.
> 3. How can i put street labels ABOVE the streets,NOT ON TOP of the
> streets. I tried OFFSET but it didn't work.
POSITION UC should place the label above and POSITION LC below in the
simplest cases...maybe you should include your layer snippet and a
screengrab of your problem, to this email list.
> 4. I set the temp path to /ms4w/tmp/ms_tmp but i don't see any image
> there when i open it. Does this mean the images are being kept
> somewhere else? where?
MS4W is configured for the following settings:
IMAGEPATH "/ms4w/tmp/ms_tmp/"
IMAGEURL "/ms_tmp/"
Your mapfiles should use those values...which means that the images will
be written to C:/ms4w/tmp/ms_tmp (for example).
> 5. Does geomoose has limit to the number of maps that should be
> added? The reason is that the application stops loading when i add more
> maps to it.
Again this is best asked on the GeoMoose mailing list.
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
