[mapserver-users] WMS don't load
Steve.Toutant at inspq.qc.ca
Mon Oct 20 10:03:34 EDT 2008
Sounds like a DNS config problem on your server... can you double-check
your network settings?
There is no proxy, no firewall the DNS seems ok since I can ping and get
to http://atlas.gc.ca
Did you try opening the URL using I.E. directly on the server that
produces the error?
YES and the image shows up.
I also tried with this WMS that everyone knows
LAYER
NAME "prov_bound"
TYPE RASTER
STATUS ON
CONNECTION "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
CONNECTIONTYPE WMS
METADATA
"wms_srs" "EPSG:42304"
"wms_name" "prov_bound"
"wms_server_version" "1.1.1"
"wms_format" "image/gif"
END
END
Same behaviour. I got a blank image. If I add a layer based on a
shapefile, I see the shapefile but not the wms.
The Os is Windows Server 2003 R2 SP2 Multilingue and IE6
Steve
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction des risques biologiques, environnementaux et occupationnels
Institut national de santé publique du Québec
945, avenue Wolfe
Québec, Qc G1V 5B3
Tél.: (418) 650-5115 #5281
Fax.: (418) 654-3144
steve.toutant at inspq.qc.ca
http://www.inspq.qc.ca
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081020/dd8914f4/attachment.html
