[mapserver-users] WMS don't load
Brent Fraser
bfraser at geoanalytic.com
Mon Oct 20 11:08:10 EDT 2008
Steve,
Perhaps running a http sniffer (such as HTTPLook) would help track down the problem?
Or maybe not. The fact that the URL works interactively using shp2img or a browser but not from a service implies that the problem might be related to the permissions of the account Apache/Mapserver/Curl is running under. Does that account have permission to access to the needed files and temporary directories?
And the fact that curl seems to be generating a error is interesting. You could try executing the url using curl from the commandline to see if curl will give more error information.
Best Regards,
Brent Fraser
Steve.Toutant at inspq.qc.ca wrote:
> Sounds like a DNS config problem on your server... can you double-check
> your network settings?
> There is no proxy, no firewall the DNS seems ok since I can ping and get
> to http://atlas.gc.ca
> Did you try opening the URL using I.E. directly on the server that
> produces the error?
> YES and the image shows up.
> I also tried with this WMS that everyone knows
> LAYER
> NAME "prov_bound"
> TYPE RASTER
> STATUS ON
> CONNECTION "http://www2.dmsolutions.ca/cgi-bin/mswms_gmap?"
> CONNECTIONTYPE WMS
> METADATA
> "wms_srs" "EPSG:42304"
> "wms_name" "prov_bound"
> "wms_server_version" "1.1.1"
> "wms_format" "image/gif"
> END
> END
> Same behaviour. I got a blank image. If I add a layer based on a
> shapefile, I see the shapefile but not the wms.
> The Os is Windows Server 2003 R2 SP2 Multilingue and IE6
> Steve
> /Steve Toutant, M. Sc./
> Analyste en géomatique
> Secteur environnement
> Direction des risques biologiques, environnementaux et occupationnels
> Institut national de santé publique du Québec
> 945, avenue Wolfe
> Québec, Qc G1V 5B3
> Tél.: (418) 650-5115 #5281
> Fax.: (418) 654-3144_
> __steve.toutant at inspq.qc.ca_ <mailto:steve.toutant at inspq.qc.ca>_
> __http://www.inspq.qc.ca_ <http://www.inspq.qc.ca/>
> mapserver-users at lists.osgeo.org
