[mapserver-users] WMS don't load
Kralidis,Tom [Burlington]
Tom.Kralidis at ec.gc.ca
Mon Oct 20 13:45:07 EDT 2008
Put the url in double quotes, i.e.:
> curl.exe "http://atlas.gc.ca/cgi-bin/atlaswms_fr?LAYERS=pe_15m&REQUEST=GetMap&SERVICE=WMS&FORMAT=image/gif&STYLES=&HEIGHT=300&VERSION=1.1.1&SRS=EPSG:4326&WIDTH=400&BBOX=-80.9516220735786,44.92,-57.1183779264214,62.78&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_xml
When I try this, I get a valid GIF image back.
..Tom
From: mapserver-users-bounces at lists.osgeo.org [mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of Steve.Toutant at inspq.qc.ca
Sent: 20 October, 2008 1:33 PM
To: Brent Fraser
Cc: mapserver-users at lists.osgeo.org
Subject: Re: [mapserver-users] WMS don't load
Are you familiar with curl? I don't what is it and whait it is supposed to return.
I downloaded curl.exe anyway but I need help. What is the url I should send?
I tried
curl.exe http://atlas.gc.ca/cgi-bin/atlaswms_fr?LAYERS=pe_15m&REQUEST=GetMap&SERVICE=WMS&FORMAT=image/gif&STYLES=&HEIGHT=300&VERSION=1.1.1&SRS=EPSG:4326&WIDTH=400&BBOX=-80.9516220735786,44.92,-57.1183779264214,62.78&TRANSPARENT=TRUE&EXCEPTIONS=application/vnd.ogc.se_inimage
But I just get a bunch of error
<HTML>
<HEAD><TITLE>MapServer Message</TITLE></HEAD>
<!-- MapServer version 5.0.2-AoC OUTPUT=GIF OUTPUT=PNG OUTPUT=JPEG OUTPUT=WBMP O
UTPUT=SVG SUPPORTS=PROJ SUPPORTS=AGG SUPPORTS=FREETYPE SUPPORTS=WMS_SERVER SUPPO
RTS=WMS_CLIENT SUPPORTS=WFS_SERVER INPUT=EPPL7 INPUT=POSTGIS INPUT=OGR INPUT=GDA
L INPUT=SHAPEFILE -->
<BODY BGCOLOR="#FFFFFF" onload="parent.window.ctl.displayErrorMessage();">
mapserv(): Web application error. Traditional BROWSE mode requires a TEMPLATE in
the WEB section, but none was provided.
</BODY></HTML>'REQUEST' is not recognized as an internal or external command,
operable program or batch file.
'SERVICE' is not recognized as an internal or external command,
Invalid parameter - /gif
'STYLES' is not recognized as an internal or external command,
'HEIGHT' is not recognized as an internal or external command,
'VERSION' is not recognized as an internal or external command,
'SRS' is not recognized as an internal or external command,
'WIDTH' is not recognized as an internal or external command,
'BBOX' is not recognized as an internal or external command,
'TRANSPARENT' is not recognized as an internal or external command,
'EXCEPTIONS' is not recognized as an internal or external command,
Steve Toutant, M. Sc.
Analyste en géomatique
Secteur environnement
Direction des risques biologiques, environnementaux et occupationnels
Institut national de santé publique du Québec
945, avenue Wolfe
Québec, Qc G1V 5B3
Tél.: (418) 650-5115 #5281
Fax.: (418) 654-3144
steve.toutant at inspq.qc.ca <mailto:steve.toutant at inspq.qc.ca>
http://www.inspq.qc.ca <http://www.inspq.qc.ca/>
