[mapserver-users] WMS don't load
Jeff McKenna
jmckenna at gatewaygeomatics.com
Mon Oct 20 14:22:24 EDT 2008
Steve.Toutant at inspq.qc.ca wrote:
> and I'm running out of faith... :-)
> Yep I still get the curl error code 6. I asked my system admin to grant
> full access to everyone...same result.
Have you tested this on your own machine at home? If you have a
locked-down IIS machine trying to run MS4W I agree with Daniel that it
is probably a permissions issue. (in other words, try this outside of
your work environment, and if all is ok there, then you know that it has
something to do with your security at work)
Jeff McKenna
FOSS4G Consulting and Training Services
http://www.gatewaygeomatics.com/
