[mapserver-users] Using JOIN and FILTERITEM
Nelson Soto
NSoto at plotplans.com
Tue Oct 21 10:48:10 EDT 2008
Hello,
Can I use FILTERITEM after I have done a JOIN?
I keep getting an error stating it can not find the JOINed field when
FILTERITEM is used...
LAYER # Parcels Polygon Layer
NAME 'ParcelsAvailableSearch'
DATA 'parcels_tiles/parcels.shp'
STATUS DEFAULT
TYPE POLYGON
METADATA
qstring_validation_pattern '.'
END
TEMPLATE 'parcels/itemquery_parcels_flag.html'
JOIN
NAME extend
TABLE 'parcels_tiles/joint.dbf'
FROM 'LOC_ID'
TO 'LOC_ID'
TYPE ONE-TO-ONE
END
FILTERITEM 'FLD_INT'
FILTER /%id4%/
CLASS
SYMBOL 'plainline'
SIZE 3
COLOR -1 -1 -1
OUTLINECOLOR 255 255 0
END
END
Joint.dbf consists of two fields, LOC_ID and FLD_INT. I need FLD_INT but
it is subject to change so I need it in a separate file. So, I want to
generate an item query of everything that matched the FLD_INT which is
set by another program before hand. Can this be done?
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081021/5d06dfca/attachment.html
