[mapserver-users] Using JOIN and FILTERITEM
Guillaume Sueur
guillaume.sueur at neogeo-online.net
Tue Oct 21 10:59:22 EDT 2008
>From http://mapserver.gis.umn.edu/docs/reference/mapfile/join/html2pdf :
Joins are defined within a LAYER object. It is important to understand
that JOINs are ONLY available once a
query has been processed. You cannot use joins to affect the look of a
map. The primary purpose is to enable
lookup tables for coded data (e.g. 1 => Forest) but there are other
possible uses.
Regards,
Guillaume
Nelson Soto a écrit :
> Hello,
> Can I use FILTERITEM after I have done a JOIN?
> I keep getting an error stating it can not find the JOINed field when
> FILTERITEM is used…
> LAYER # Parcels Polygon Layer
> NAME 'ParcelsAvailableSearch'
> DATA 'parcels_tiles/parcels.shp'
> STATUS DEFAULT
> TYPE POLYGON
> METADATA
> qstring_validation_pattern '.'
> END
> TEMPLATE 'parcels/itemquery_parcels_flag.html'
> JOIN
> NAME extend
> TABLE 'parcels_tiles/joint.dbf'
> FROM 'LOC_ID'
> TO 'LOC_ID'
> TYPE ONE-TO-ONE
> END
> FILTERITEM 'FLD_INT'
> FILTER /%id4%/
> CLASS
> SYMBOL 'plainline'
> SIZE 3
> COLOR -1 -1 -1
> OUTLINECOLOR 255 255 0
> END
> END
> Joint.dbf consists of two fields, LOC_ID and FLD_INT. I need FLD_INT but
> it is subject to change so I need it in a separate file. So, I want to
> generate an item query of everything that matched the FLD_INT which is
> set by another program before hand. Can this be done?
> mapserver-users at lists.osgeo.org
Guillaume SUEUR
Gérant
Neogeo Technologies SARL
46 RUE MATABIAU
31000 TOULOUSE
Tél : +33 6 74 91 95 20
http://www.neogeo-online.net
