[mapserver-users] disk space
valerio vianello
valerio.vianello at yahoo.it
Thu Oct 23 08:47:09 EDT 2008
Sorry but i still not understand...
my scenario is client-server , in the server side I have a java servlet as an interface between the client and mapserver. now if i understood i would have to delete the tmp image on the server after the servlet send beck the answer to the client. But How I can be sure that the client download the image before I delete it ?
Thanks
Valerio
--- Gio 23/10/08, Venkat Rao Tammineni <vtammineni at roulacglobal.com> ha scritto:
Da: Venkat Rao Tammineni <vtammineni at roulacglobal.com>
Oggetto: RE: [mapserver-users] disk space
A: valerio.vianello at yahoo.it, "'mapserver'" <mapserver-users at lists.osgeo.org>
Data: Giovedì 23 ottobre 2008, 13:33
See after click or whatere it is …. OnOPageprerender Image
will be creating an image. And after creation image will be deleting.what my
project is doing the same.I am giving that code.. below…
protected override
void OnPreRender(EventArgs
e)
LaodMainMap(ibMap);
//Load MainMap by
public void
LaodMainMap(System.Web.UI.WebControls.ImageButton
imgMap)
MapFunction.Deleteimages();//delete Image form temp folder
string
imageLoc;
string
imageURL;
imageObj
imgRef;
imgRef = MapFunction.Map.drawQuery();
imageLoc = MapFunction.OutputDir + "/" + System.DateTime.Now.ToBinary()
+ "." + imgRef.format.extension;
imageURL =
imageLoc.Substring(imageLoc.IndexOf(MapFunction.OutputDirURL));
imgRef.save(imageLoc, null);
ibMap.Width = imgRef.width;
ibMap.Height = imgRef.height;
ibMap.ImageUrl = imageURL;
MapFunction.IsMapInDirectory = false;
This on Page Load
//Temp folder for storing legend map and
keymap temp files
MapFunction = new
RoulacGIS.MapFunctionality(this.Page, Server.MapPath(_AppSetting.TempFolder),
_ AppSetting.TempFolder);
//initialize
map control
//Load
Map
try
{ LoadMap(); }
catch
(Exception exp)
{ exp.Message.ToString(); }
//this is separate method for accessing
mapfile
public void LoadMap()
{ MapFunction.Map = new mapObj(Server.MapPath("MapFile/")
+ _AppSetting.MapFilePath); } //create map instance
I hope this will help you.
Thanks and Regards,
Venkat.
[mailto:valerio.vianello at yahoo.it]
Sent: Thursday, October 23, 2008 4:36 PM
To: 'mapserver'; Venkat Rao Tammineni
Subject: RE: [mapserver-users] disk space
Thanks for the quick reply,
When you run this function? after each requests ? but if so, the client is
able to read the image before you delete it ?
best regards,
Valerio
Data: Giovedì 23 ottobre 2008, 13:05
Why don’t you write method for deleting png .mapserver will take care
about creating an image.I have C# code.
The
below code will delete all the files form OutputDIR.
I
hope it helps you. Or At least you can get some idea about your task.
Thanks
and Regards
Venkat.
public void
Deleteimages()
try
foreach (string
f in System.IO.Directory.GetFiles(OutputDir))
System.IO.File.Delete(f);
catch (Exception
exp)
[mailto:mapserver-users-bounces at lists.osgeo.org] On Behalf Of valerio
vianello
Sent: Thursday, October 23, 2008 4:25 PM
To: mapserver
Subject: [mapserver-users] disk space
Dear
all,
I have a demo where I'm using mapserver cgi interface. I'm using the browse
mode so each time mapserver receive a request, it creates a temporary png
on the server filesystem.
Do you know how and when i can delete those temporary image since they are
used only one time ?
An attacker could easily fill all the server HD locking all the
system.
Thanks
Valerio
Scopri il Blog di Yahoo! Mail:
trucchi, novità, consigli... e scrivi la tua opinione!
Scopri
il Blog di Yahoo! Mail: trucchi, novità,
Scopri il blog di Yahoo! Mail:
Trucchi, novità e scrivi la tua opinione.
http://www.ymailblogit.com/blog
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081023/93f71dcc/attachment-0001.html
