[mapserver-users] Problems With Google Earth WMS view
David Martinez Morata
damarmo at gmail.com
Thu Oct 23 09:08:10 EDT 2008
Thanks a lot!
With the outputformat thats OK , for the resloution it's better for me in
512X512. But it's a god thing to know.
Thanks
2008/10/23 Alexandre Dube <adube at mapgears.com>
> Hi David,
> > can define a resolution for the output image?
> No, but your can change the image size ( height and width ) in your GE
> Link. Default values are 512 X 512. You could change those to 1024 X 1024
> and you'll get a nicer image.
> > problems with transparency on different zoom level
> Are you using your own WMS service ? If so, I don't know which
> OUTPUTFORMAT you're using but I had png with agg and didn't have this
> problem. If you have more than one "image/png" MIMETYPE, put this one on
> top.
> OUTPUTFORMAT
> NAME "agg"
> MIMETYPE "image/png"
> DRIVER AGG/PNG
> EXTENSION "png"
> IMAGEMODE RGBA
> TRANSPARENT ON
> FORMATOPTION "INTERLACE=OFF"
> END
> Hope this can helps.
> Cheers
> Alexandre
> David Martinez Morata wrote:
>> Hello.
>> I create a WMS for GE and I found some estrange things.
>> In my Map file I don't define a background colour and I could like to be
>> Transparent, but...
>> At some levels I have the transparent image and at other levels I don't
>> have it I don't really understand Wat is happening.
>> I have 3 Layer in different zoom levels, The first One it's a line layer
>> and the others are Points layers.
>> And in some areas of my map I found problems with transparency If i put in
>> some area i have the transparency but if i change a littel bit, the
>> bacgruond becomes with.
>> And just one question:
>> Thanks
>> mapserver-users mailing list
>> mapserver-users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
> Alexandre Dubé
> Mapgears
> www.mapgears.com
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081023/64dc10f2/attachment.html
