[MAPSERVER-USERS] mapserver MSVC2005 development package
available to download (was mssql2008 binary test package available to
download)
BrainDrain
paulborodaev at gmail.com
Fri Oct 24 04:08:27 EDT 2008
WOW :clap:
Sounds pretty easy.
I'll try.
:handshake:
Paul.
Lucena, Ivan wrote:
> Paul,
> I do it all the time with GDAL makefile projects.
> What you need to do is to create a new project in VS selecting the project
> type as "make file project" that will lead you to a wizard IU where you
> are going to inform now do you want VS to call your makefile for Buil,
> Rebuild and Clean. The next step is to manually add each folder and source
> code that your want to see on the project explorer source code tree. Yes,
> it is a lot of work if you want to browse through the whole thing. See
> GDAL's makegdal_gen.bat for an automatic way of creating the source tree
> [http://trac.osgeo.org/gdal/browser/trunk/gdal/makegdal_gen.bat].
> After that it is all the same as in a regular VS project. Breakpoints,
> step-into, step-out, watch windows, etc.
> Good luck,
> Ivan
>> -------Original Message-------
>> From: BrainDrain <paulborodaev at gmail.com>
>> Subject: Re: [MAPSERVER-USERS] mapserver MSVC2005 development package
>> download)
>> Sent: Oct 24 '08 07:23
>> That's great! Thanks.
>> One question.
>> As long as I'm windows developer, spoilt by visual studio:
>> how to debug an app using IDE when building performed by makefile? When
>> no
>> VS project/solution file available? How you doing this? (tools/methods
>> (debug console output? without 'watch window'?)).
>> Best regards,
>> Paul
>> Tamas Szekeres wrote:
>> > Here is my daily snapshot including the fast cgi support:
>> > http://vbkto.dyndns.org:1280/tests/release-1400-20081023.zip
>> > I've created a development package to compile mapserver from the
>> sources:
>> > http://vbkto.dyndns.org:1280/tests/release-1400-dev.zip
>> > You can use the following steps to compile mapserver.
>> > 1. Extract the contents to a directory (for example
>> > "C:\builds\release-1400-dev")
>> > 2. Open Microsoft Visual Studio 2005 Command Prompt
>> > 3. > cd C:\builds\release-1400-dev
>> > 4. > nmake -f makefile.vc ms MS_DIR=mapserver
>> > BASE_DIR=C:\builds\release-1400-dev
>> > 5. > nmake -f makefile.vc ms-sql2008 MS_DIR=mapserver
>> > 5. > nmake -f makefile.vc ms-csharp MS_DIR=mapserver
>> > This package is based on the development version of gdal and
>> > mapserver, but you can download the stable version of gdal and
>> > mapserver sources in the base directory if you require a stable
>> > version build
>> > In this case you must specify these directories for MS_DIR and
>> > GDAL_DIR at the command like, like:
>> >> nmake -f makefile.vc gdal GDAL_DIR=gdal-1-5
>> >> nmake -f makefile.vc ms MSL_DIR=mapserver-5-2
>> > If you require a corresponding package for the MSVC2003 based builds
>> > let me know.
>> > Best regards,
>> > Tamas
>> > 2008/10/20 BrainDrain <paulborodaev at gmail.com>:
>> >> Thank you very much, Tamas.
>> >> getFeature works fine now.
>> >> But can I ask you for one more favour. Could you compile with fastcgi
>> >> support (ideally with all ms4w production release flags) or share
>> 'your
>> >> working buildkit' (this just will be great!, not only for me) because
>> I
>> >> still have problems with compiling ms4w(( but I need sql2008 support
>> >> feature
>> >> as soon as it possible for my work. I would be very appreciate.
>> >>> Folks,
>> >>> Yes, I've run into the same issue when using the getFeature method
>> >>> with the driver. Here is the corresponding ticket I've created:
>> >>> http://trac.osgeo.org/mapserver/ticket/2795
>> >>> Attached the C# test case with this ticket:
>> >>> http://trac.osgeo.org/mapserver/attachment/ticket/2795/Program.cs
>> >>> I've fixed this issue in the SVN-trunk and the stable branch, here
>> is
>> >>> my daily snapsot of the binaries you can test with:
>> >>> http://vbkto.dyndns.org:1280/tests/release-1400-20081018.zip
>> >>> If you encounter further problems with the driver don't hesitate to
>> >>> file a ticket describing the issue.
>> >>> Just for a note: This driver doesn't make any character encodings
>> with
>> >>> the values retieved as plain byte arrays from MSSQL, however your
>> >>> default database setting corresponds to the
>> >>> 1251 codepage, so explicit character conversion may be required in
>> C#,
>> >>> like:
>> >>> byte[] bytes = Encoding.Convert(Encoding.Unicode, Encoding.Default,
>> >>> Encoding.Unicode.GetBytes(shape.getValue(k)));
>> >>> string str = Encoding.GetEncoding(1251).GetString(bytes);
>> >>> Best regards,
>> >>> Tamas
>> >>> 2008/10/17 BrainDrain <paulborodaev at gmail.com>:
>> >>>> hmm
>> >>>>>>could you provide an example to this
>> >>>> how can I help If I use mapscript?
>> >>>> [WebService(Namespace = "http://www.wem.volgadmin.ru/wemlib")]
>> >>>> [WebServiceBinding(ConformsTo = WsiProfiles.None)]
>> >>>> [ScriptService]
>> >>>> public class MapParser : System.Web.Services.WebService
>> >>>> [WebMethod(EnableSession = true)]
>> >>>> [ScriptMethod(UseHttpGet = true)]
>> >>>> public object RequestFeatureAttributes(object mapIndex,
>> object
>> >>>> layerIndex, int[] featureIndexes, string[] fieldNames, bool
>> envelope)
>> >>>> mapObj map;
>> >>>> layerObj layer = null;
>> >>>> shapeObj shape;
>> >>>> int entryIndex = -1, i, j, len = featureIndexes.Length;
>> >>>> object[] res = new object[len];
>> >>>> Dictionary<string, object> valueBag, record;
>> >>>> if (Util.isNumeric(mapIndex.ToString(),
>> >>>> NumberStyles.Integer))
>> >>>> mapIndex = (object)Convert.ToInt32(mapIndex);
>> >>>> if (Util.isNumeric(layerIndex.ToString(),
>> >>>> layerIndex = (object)Convert.ToInt32(layerIndex);
>> >>>> KeyValuePair<string, object> entry =
>> >>>> Util.getEntry((Dictionary<string, object>)Session["maps"],
>> >>>> (mapIndex.GetType() == typeof(int)) ? mapIndex :
>> >>>> Util.normalizePath((string)mapIndex), out entryIndex);
>> >>>> map = (mapObj)entry.Value;//.clone()
>> >>>> if (layerIndex.GetType() == typeof(int))
>> >>>> layer = map.getLayer((int)layerIndex);
>> >>>> else
>> >>>> if (layerIndex.GetType() == typeof(string))
>> >>>> layer = map.getLayerByName((string)layerIndex);
>> >>>> layer.open();
>> >>>> object def;
>> >>>> List<int> fieldIndexes = new List<int>();
>> >>>> List<string> list = new List<string>();
>> >>>> if (fieldNames != null)
>> >>>> for (i = 0; i < layer.numitems; i++)
>> >>>> if
>> >>>> (((ICollection<string>)fieldNames).Contains(layer.getItem(i)))
>> >>>> fieldIndexes.Add(i);
>> >>>> for (i = 0; i < len; i++)
>> >>>> try
>> >>>> using (shape =
>> layer.getFeature(featureIndexes[i],
>> >>>> -1))
>> >>>> //here exception occurs
>> >>>> string[] values;
>> >>>> if (fieldNames.Length > 0)
>> >>>> list.Clear();
>> >>>> for (j = 0; j < fieldIndexes.Count;
>> j++)
>> >>>> list.Add(shape.values[fieldIndexes[j]]);
>> >>>> values = list.ToArray();
>> >>>> else
>> >>>> values = new string[1] {
>> >>>> featureIndexes[i].ToString() };
>> >>>> else
>> >>>> values = shape.values;
>> >>>> valueBag = new Dictionary<string, object>();
>> >>>> for (j = 0; j < values.Length; j++)
>> >>>> valueBag[j.ToString()] = values[j];
>> >>>> if (envelope)
>> >>>> record = new Dictionary<string,
>> object>();
>> >>>> if (len > 1)
>> >>>> record[featureIndexes[i].ToString()]
>> >>>> (object)valueBag;//?
>> >>>> else
>> >>>> record[entryIndex.ToString() + ' ' +
>> >>>> layer.index.ToString() + ' ' + featureIndexes[i].ToString()] =
>> >>>> res[i] = record;
>> >>>> else
>> >>>> res[i] = valueBag;
>> >>>> catch { }
>> >>>> layer.close();
>> >>>> return (len > 1) ? ((envelope) ? new Dictionary<string,
>> >>>> object>() { { entryIndex.ToString() + ' ' + layer.index.ToString(),
>> res
>> >>>> : (object)res) : res[0];
>> >>>> Again access violation exception after modifying mapfile.
>> >>>> Sql profiler says that query batch (select convert(varchar(max),
>> >>>> STATUS),convert(varchar(max), STAGE),convert(varchar(max), id),GEOM
>> >>>> from
>> >>>> dbo.Construct where id = 190748) completed successfully
>> >>>>> 2008/10/16 BrainDrain <paulborodaev at gmail.com>:
>> >>>>>> -without "WITH(INDEX..." in mapfile data section - mem corruption
>> >>>>>> exception
>> >>>>>> on "shape = layer.getFeature(featureIndexe, -1)" after successful
>> >>>>>> execution
>> >>>>>> of queryByPoint (querying the largest polygon in my geodb);
>> >>>>> I didn't encounter any memory corruption error here, could you
>> provide
>> >>>>> an example to this?
>> >>>>> I've set up your database with IIS and apache with the following
>> >>>>> links:
>> http://vbkto.dyndns.org:1280/cgi-bin/mapserv.exe?mode=map&map=test2008.map
>> http://vbkto.dyndns.org:1080/cgi-bin/mapserv.exe?mode=map&map=test2008.map
>> >>>>>> -with using "WITH(INDEX...":
>> >>>>>> msMSSQL2008LayerGetShape(): Query error. Error executing
>> MSSQL2008
>> >>>>>> SQL
>> >>>>>> statement: select convert(varchar(max),
>> >>>>>> STAGE),convert(varchar(max), id),GEOM from dbo.Construct
>> >>>>>> WITH(INDEX(SIndx_Construct_geometry_geom)) where id = 190748
>> >>>>>> -[Microsoft][ODBC SQL Server Driver][SQL Server]Query processor
>> could
>> >>>>>> not
>> >>>>>> produce a query plan because of the hints defined in this query.
>> >>>>>> Resubmit
>> >>>>>> the query without specifying any hints and without using SET
>> >>>>>> FORCEPLAN.
>> >>>>>> When I'm trying to execute this select statement in man. studio -
>> >>>>>> error
>> >>>>>> message - the same.
>> >>>>>> I think because where clause don't contains conditions related to
>> >>>>>> spatial
>> >>>>>> index used in 'WITH' hint.
>> >>>>> You're right, just looking into the code here is a possible
>> solution:
>> >>>>> DATA "GEOM from dbo.Construct USING UNIQUE id USING SRID=0 USING
>> INDEX
>> >>>>> SIndx_Construct_geometry_geom"
>> >>>>> Best regards,
>> >>>>> Tamas
>> >>>>> _______________________________________________
>> >>>>> mapserver-users mailing list
>> >>>>> mapserver-users at lists.osgeo.org
>> >>>>> http://lists.osgeo.org/mailman/listinfo/mapserver-users
>> >>>> View this message in context:
>> http://www.nabble.com/mssql2008-binary-test-package-available-to-download-tp19956347p20027820.html
>> >>>> Sent from the Mapserver - User mailing list archive at Nabble.com.
>> http://www.nabble.com/mssql2008-binary-test-package-available-to-download-tp19956347p20065718.html
>> http://www.nabble.com/mapserver-MSVC2005-development-package-available-to-download-%28was-mssql2008-binary-test-package-available-to-download%29-tp20129726p20145478.html
View this message in context: http://www.nabble.com/Re%3A-mapserver-MSVC2005-development-package%09available-to-download-%28was-mssql2008-binary-test-package-available-to%09download%29-tp20145775p20146041.html
