[mapserver-users] Clear projecton from layerObj
Pietro Giannini
pgiannini at bytewise.it
Fri Oct 24 12:09:31 EDT 2008
You can not.
The layer object has always a projection. If not set in the PROJECTION
section of the layer in the mapfile, it assume the projection of the
mapfile.
You must assign to the layer object the projection of the map object:
layerObj.setProjection(mapObj.getProjection());
ciao
...............................pg
Pietro Giannini
Bytewise srl - Area GIS
41°50'38.58"N 12°29'13.39"E
On Ven, Ottobre 24, 2008 17:46, Murty Maganti wrote:
> Hello
> How to remove (or clear) a projection information set to a layer using
> C# map script. For example, I have set a projection information to a
> layer using the code
> layerObj.setProjection("init=EPSG:4326");
> Now I want to clear this projection and set the layer to its original
> (unknown )status. I don't find any API on the layerObj to clear the
> projection information.
> Thanks
> Murty
> mapserver-users at lists.osgeo.org
