[mapserver-users] WMS TIME using postgis time index, problem
with GetFeatureInfo
Yewondwossen Assefa
yassefa at dmsolutions.ca
Fri Oct 24 15:47:54 EDT 2008
Maarten,
Maarten Plieger wrote:
> Hi All,
> I use a postgis database filled with files and their corresponding
> dates. This makes it possible to use WMS Time requests. This works very
> well, except for the GetFeatureInfo request. When I do GetFeatureInfo on
> a certain location I get this message:
> "msSHPOpenFile(): Unable to acces file.
> (/mapdata/RADNL25TIME)"
> The data is raster data, and has nothing to do with Shapes...
> This is a part of the mapfile of the layer:
> TILEITEM "path" #path is a column in postgis table with varchar of the
> filepath to each image
> TILEINDEX "RADNL25TIME"
> METADATA
> "wms_timeextent"
> "2008-10-24T00:00:00Z/2008-10-24T12:00:00Z/PT5M"
> "wms_timeitem" "datetime" #datetime is a column in
> postgis table of type timestamp
> "wms_timedefault" "2008-10-24T00:00:00Z"
> END
> Is this a known bug, or am I doing something wrong?
> When I use a file directly instead of the PostGIS table, GetFeature info
> returns the correct results.
Maarten,
Your request of GetFeatureInfo ends up being equivalent of a query on
a tiled index raster layer. From what I can see, Mapserver seems to be
currently limited to only be able to do queries when the tiled layer is
a shape file. I have raised an enhancement bug on this
(http://trac.osgeo.org/mapserver/ticket/2796) but I am not sure how easy
It would be to support all data types in this case. (We should at least
be able to send a meaningful message to the user explaining the limitation).
Meanwhile, you might want to consider making your layer non queryable.
Best Regards
Assefa Yewondwossen
Software Analyst
Email: assefa at dmsolutions.ca
http://www.dmsolutions.ca/
Phone: (613) 565-5056 (ext 14)
Fax: (613) 565-0925
