VS: [mapserver-users] projection = geographer's pain
Rahkonen Jukka
Jukka.Rahkonen at mmmtike.fi
Mon Oct 27 07:46:27 EDT 2008
Have you double-checked that your map extent correspods with the map projection?
Or if you could send your whole mapfile I am pretty sure that you will get a final answer to your problem.
-Jukka Rahkonen-
> -----Alkuperäinen viesti-----
> Lähettäjä: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Puolesta
> Monier Clement
> Lähetetty: 27. lokakuuta 2008 13:39
> Vastaanottaja: 'Pietro Giannini'; mapserver-users at lists.osgeo.org
> Aihe: RE: [mapserver-users] projection = geographer's pain
> Thanks for your answers Roger & Pietro.
> I've followed your advice by trying these 4 test-cases :
> 1)
> Map proj set to : "init=epsg:3785" (web spherical Mercator,
> manually added
> into espg file)
> Layer proj set to : "init=epsg:4326" (latlon wgs84, proj system of my
> shapefiles)
> => got a blank map
> 2)
> Map projection set to : "init=epsg:4326"
> Layer projection set to : "init=epsg:4326"
> => got a map
> 3)
> Map projection set to : "init=epsg:3785"
> Layer projection set to : "init=epsg:3785"
> => got the same map as 2)
> 4)
> => got a blank map
> I've also tried with another well-known existing epsg
> proj-system (instead of the manually-added 3785 code), but
> got the same results.
> I've made other attempts by replacing "init=3785" by full
> description proj-string like "+proj=longlat +ellps=WGS84
> +datum=WGS84 +no_defs no_defs"
> or "+proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
> +x_0=0.0 +y_0=0
> +k=1.0 +units=m +nadgrids=@null no_defs"
> But it didn't change anything...
> It seems that :
> - a map is drawn only if the map's and layer's proj-systems
> are the same.
> - the output projection is always overridden by the shapefile
> system, no re-projection is done anyway.
> Let me know if you have any further leads to solve this issue.
> Thanks for your help
> Clément
> -----Message d'origine-----
> De : mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] De la part
> de Pietro Giannini Envoyé : vendredi 24 octobre 2008 21:40 À
> : mapserver-users at lists.osgeo.org Objet : Re:
> I can confirm that projection is often a pain!
> However, the problem may be in the projection of the layer.
> The PROJECTION section in a layer declare the projection of
> the data source of this layer, while the PROJECTION on the
> map level is the projection wich you want to show the whole
> map. So you can overlay more data sources in different
> projection in a single map.
> Try to set the layer PROJECTION as "init=epsg:4326".
> Let us know...
> ciao
> ........................... pg
> Pietro Giannini
> Bytewise srl - Area GIS
> 41°50'38.58"N 12°29'13.39"E
> On Ven, Ottobre 24, 2008 16:55, Monier Clement wrote:
> > Hi,
> > I'm running MS4W v2.2.8 (including MapServer 5.2) on windows.
> > My datasource is shapefiles with WGS84 projection (epsg:4326).
> > I would like MapServer to render these data into a "Web (spherical)
> > Mercator" projected map (epsg:3785) in order to perfectly
> overlay the
> > GoogleMaps tile images (for the moment, my maps are slightly shifted
> > north.)
> > I've added this string at the end of the file "epsg" in
> /ms4w/proj/nad :
> > <3785> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0
> +lon_0=0.0 +x_0=0.0
> > +y_0=0 +k=1.0 +towgs84=0,0,0,0,0,0,0 +units=m
> +nadgrids=@null +no_defs <>
> > But I don't know how to modify my request and mapfile in
> order to get the
> > correct map.
> > I've tried many combinations so far but with no success until now.
> > Do I have to change the projection system of my shapefiles ?
> > Is MapServer able to change projection between input and output ?
> > Request : "&SRS=epsg:3785"
> > MapFile :
> > [Map section]
> > METADATA
> > "wms_srs" "EPSG:4326 EPSG:3785" # is this correct ?
> > END
> > PROJECTION
> > "init=epsg:3785" # is this correct ?
> > END
> > [Layer section]
> > METADATA
> > "wms_srs" "EPSG:3785" # is this correct ?
> > END
> > PROJECTION
> > END
> > With these settings, the pictures I got from MapServer are
> still shifted.
> > Clement
> > mapserver-users mailing list
> > http://lists.osgeo.org/mailman/listinfo/mapserver-users
