[mapserver-users] GetCoverage and palette Geotiffs
Alexander Petkov
greenkov at gmail.com
Mon Oct 27 15:01:47 EDT 2008
Hi Frank:
Thanks for your reply. I'll try IMAGEMODE BYTE--if I remember
correctly I tried it before and the results was a grayscale (although
single band, yay!) image. I'll try to make it work for me.
Alex
On Mon, Oct 27, 2008 at 12:43 PM, Frank Warmerdam <warmerdam at pobox.com> wrote:
> Alexander Petkov wrote:
>> Would it be possible to preserve the original data in an image (number
>> of bands, and Type, and color interp) in the result of a GetCoverage
>> request? For example, I serve Paletted Geotiffs through mapserver:
>> Any hopes of being able to preserve the orig data after a GetCoverage
>> request?
> Alex,
> The original pixel values can be preserved by picking an IMAGEMODE BYTE
> outputformat, but unfortunately that will currently discard the palette.
> Basically there are two major rendering paths involved here. One is a
> map view oriented one (GD'ish renders - IMAGEMODE RGB, RGBA or PC256) and
> the other is a raw data oriented path (GDAL'ish renders - IMAGEMODE BYTE,
> INT16 and FLOAT32).
> We could look at trying to preserve palettes and possible some other stuff
> in the "raw data" case but I'm not terrible keen on doing this.
> Best regards,
> I set the clouds in motion - turn up | Frank Warmerdam,
> light and sound - activate the windows | http://pobox.com/~warmerdam
> and watch the world go round - Rush | Geospatial Programmer for Rent
