[mapserver-users] Serving large raster images using Tile Cache.
Asif Memon
mmemon at sdsc.edu
Tue Oct 28 17:35:14 EDT 2008
I am working on the stand alone java based application that loads up the
images of anywhere from 2GB to 30 GB.
1) I read the documentation, and found out the tilecache can be done
using GDAL utilities, please see below an example -
Usage: gdaltindex [-tileindex field_name] index_file [gdal_file]*
eg.
% gdaltindex doq_index.shp doq/*.tif
2) Is this the correct way of breaking an image into tiles? I see that
the image in converted into the shape files and not in a bunch of image
tiles. Am I doing something wrong here?
3) I also looked at openlayers, it wouldn't fit my requirements as it is
all javascript and my application is a stand alone java based
application, so I would need some java API to view these tiles.
Any help is much appreciated.
Sincerely,
Asif Memon
-----Original Message-----
Sent: Monday, October 20, 2008 12:17 PM
To: Asif Memon
Subject: Re: [mapserver-users] RE: Documentation for serving large
raster images using tile cache.
Asif Memon wrote:
> Thanks Gregor. I am new to the Map Server, could you please point me
to
> the documentation for setting up the Minnesota map server to serve the
> imagery. I will use WMS to view the sample imagery.
Check out the documentation:
http://mapserver.gis.umn.edu/docs
> I am not sure about
> the Open Layers app(Is there any installer that I need to install) and
> the TC's URL?
www.openlayers.org
www.tilecache.org
I think that OpenLayers is not the only TileCache consumer, but I don't
know of any others specifically.
Gregor Mosheh / Greg Allensworth BS, A+, Network+, Security+, Server+
System Administrator, Lead Programmer
HostGIS development & hosting services, http://www.HostGIS.com/
"Remember that no one cares if you can back up,
only if you can restore." - AMANDA
