[MAPSERVER-USERS] [Postgis] Intersection on requested data
G. Tiemens
Gerben.Tiemens at grontmij.nl
Thu Oct 30 06:19:29 EDT 2008
For some reason the copy paste didn't work, so here a repost of the error of
Mapserver:
<?xml version='1.0' encoding="ISO-8859-1" standalone="no" ?>
<!DOCTYPE ServiceExceptionReport SYSTEM
"http://schemas.opengis.net/wms/1.1.1/exception_1_1_1.dtd">
<ServiceExceptionReport version="1.1.1">
<ServiceException>
msDrawMap(): Image handling error. Failed to draw layer named
'KLLine'.
prepare_database(): Query error. Error declaring cursor: ERROR: syntax
error at or near "POLYGON"
LINE 1: ...ST_Intersection(kl_l.the_geom , ST_GeomFromText('
POLYGON((1...
With query string: DECLARE mycursor BINARY CURSOR FOR SELECT
"ck_6thmklc"::text,"ct_6dkel00"::text,asbinary(force_collection(force_2d(ST_Intersection(kl_l.the_geom
, ST_GeomFromText(' POLYGON((165607 387820 , 165651 387813 , 165672
387759 , 165598 387800 , 165607 387820 )) ' , 28992)
))),'NDR'),gid::text from kl_l WHERE (ST_Intersects(kl_l.the_geom ,
ST_GeomFromText('POLYGON((165607 387820 , 165651 387813 , 165672
387759 , 165598 387800 , 165607 387820 ))' , 28992) )) and
(ST_Intersection(kl_l.the_geom , ST_GeomFromText(' POLYGON((165607
387820 , 165651 387813 , 165672 387759 , 165598 387800 , 165607 387820
)) ' , 28992) ) && setSRID( 'BOX3D(165700 387800,165800
387900)'::BOX3D,find_srid('','kl_l','ST_Intersection(kl_l.the_geom
387759 , 165598 387800 , 165607 387820 )) ' , 28992) )') ))
</ServiceException>
</ServiceExceptionReport>
G. Tiemens wrote:
> To add to my previous post:
> This is the error given by MapServer:
> Greetings
> Gerben
> -----Oorspronkelijk bericht-----
> Van: mapserver-users-bounces at lists.osgeo.org
> [mailto:mapserver-users-bounces at lists.osgeo.org] Namens G. Tiemens
> Verzonden: Wednesday, October 29, 2008 4:12 PM
> Aan: mapserver-users at lists.osgeo.org
> Onderwerp: [MAPSERVER-USERS] [Postgis] Intersection on requested data
> Hello all,
> Is it possible to do an intersection on the requested data?
> I want to make a data query to the postgis, where the data will be
> intersected and delivered to mapserver for display process.
> Here is what i already reached:
> CONNECTIONTYPE postgis
> CONNECTION 'host=127.0.0.1 user=postgres password=postgres dbname=OM'
> DATA "the_geom FROM kl_l USING UNIQUE gid USING SRID = 28992"
> FILTER "ST_Intersects(kl_l.the_geom , ST_GeomFromText('POLYGON((165607
> ))' , 28992) )"
> This works fine. The data returned is the features that intersect. But
> this returns the whole feature, instead of the intersection part itself.
> So i tried to get the intersection:
> DATA "ST_Intersection(kl_l.the_geom , ST_GeomFromText('POLYGON((165607
> ))' , 28992) ) FROM kl_l USING UNIQUE gid USING SRID = 28992"
> ))' , 28992) )"
> The full query works fine on the postgis database:
> select ST_Intersection(kl_l.the_geom , ST_GeomFromText('POLYGON((165607
> ))' , 28992) ) FROM kl_l where ST_Intersects(kl_l.the_geom ,
> ST_GeomFromText('POLYGON((165607 387820 , 165651 387813 , 165672 387759
> The part where mapserver is complaining is the single quote just before
> POLYGON in the DATA statement.
> I tried single quotes inside double quotes, tried double quotes inside
> single quotes, both give the same error.
> Is there any way of retrieving the intersected features?
> Greets
> Gerben
> http://www.nabble.com/-Postgis--Intersection-on-requested-data-tp20229230p20229230.html
> Sent from the Mapserver - User mailing list archive at Nabble.com.
> << Please read our E-mail Disclaimer at the Grontmij Corporate website >>
View this message in context: http://www.nabble.com/-Postgis--Intersection-on-requested-data-tp20229230p20243971.html
