[mapserver-users] Mapserver & ECW in Linux
Carlos Ruiz
boolean10001 at yahoo.com
Thu Oct 30 15:31:23 EDT 2008
Hi list,
I use the Fedora distribution, don't know what else can I do because I can't display ECW
raster files. This is what i've done:
I downloaded de ECW toolkit and then i did this:
./configure
./make
./make install
Then i configure and make the gdal to support ECW
./configure --with-png --with-libtiff --with-jpeg --with-gif --with-ecw=/usr/local --with-pg=/usr/local/pgsql/bin/pg_config --with-geos --without-libtool
./make
./make install
Then i configure and make Mapserver
./configure --with-proj=/usr/lib --with-geos=/usr/bin/geos-config --with-ogr=/usr/local/bin/
gdal-config --with-gdal=/usr/local/bin/gdal-config --with-wms-server --with-wmsclient
--with-wfs --with-wfsclient --with-postgis=/usr/local/pgsql/bin/pg_config --with-curl-config=
/usr/bin/curl-config --with-httpd=/usr/local/apache2/bin/httpd --with-php=/usr/local/php-5.2.6
IC Carlos Ruiz
URL: http://lists.osgeo.org/pipermail/mapserver-users/attachments/20081030/cb96e998/attachment.html
